How to modify Location parameter via SOAP in CUCM
Answered Question
May 14th, 2010
Does anyone knows how to modify Audio bandwidth parameter in Locations via SOAP? Is there any example?
Thanks in advance.
Correct Answer by Aaron Harrison about 6 years 10 months ago
You would need to issue a SOAP updateLocation request, as per the AXL spec.
The interface spec is documented here: (http://developer.cisco.com/web/axl/docs - pick the appropriate spec for your CM version)
Are you new to SOAP, or do you have some existing SOAP scripts you use for another purpose? If so what language?
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Fri, 05/14/2010 - 01:30
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
