IPS Thread Issue
May 14th, 2010
Dear Cisco,
One of my customer facing issue after upgradation of IPS ver from 6.1 to 6.2 E4 that when i check the status of thread in yellow in IDM it will show more than three thousand but suddenly when i go in the options and check the real time thread it will not shown three thousands it will only show 20 thread. I also attached the sanp shot of IPS 4255 for understanding the issue. Your responses will get some solution to resolve this issue.
Thanks & Regards,
Salman Ahmed
Jennifer Halim Fri, 05/14/2010 - 01:15
The yellow threats on IME is only showing the last 5 minutes, hence you are not seeing the previous number of above 3000 threats anymore.
If you are interested to see what events they actually are, you can go to event monitoring and check the event logs for the time when you were seeing the huge number of yellow threats.
Hope that helps.
