'MAX CDR records" parameter in CCM version 6
May 14th, 2010
Hello Everyone,
Where can I find the 'MAX CDR records" in CCM version 6? and what is the appropriate value to be set? Should it be left to default value?
Thank you very much in advance.
htluo Fri, 05/14/2010 - 04:59
  • Red, 2250 points or more
You may find it in the car:tbl_system_preferences table.  I would leave it as default.
admin:run sql select * from car:tbl_system_preferences
param_name                param_value
MIN_DATE                  01/01/1970
MAX_DATE                  01/01/1970
CDR_MIN_DATE              01/01/1970
CDR_MAX_DATE              01/01/1970
MAX_CDR_NUMBER            2000000
MAX_ERROR_RECORD_ID       1
COMPANY_NAME
TOLL_FREE                 1800,1855,1866,1877,1888
CHARGELIMIT               200.00
GOOD                      20.00
POOR                      30.00
DEFAULT_CAR_USER          _unspecifieduser
LOADER_STATUS             1
CONTINUOUS_LOADING_24_7   1
LOAD_CDR_ONLY             1
MANUAL_PURGE_STATUS       0
LOADER_SCHEDULE_BACKUP    DailyCdrLoad,L,1440,-1,00:00:00,0,300,30
PURGE_LOW_WATER_MARK      80
PURGE_HIGH_WATER_MARK     90
MIN_CAR_DATABASE_AGE      2
MAX_CAR_DATABASE_AGE      60
LAST_PROCESSING_DIRECTORY
LAST_PROCESSING_FILE
LAST_PROCESSING_DATA_ROW
UPDATE_STATISTICS_DATE    05/14/2010,0
LOADER_BATCH              600,600,2500,3000
INSTALLATION_DATE         2/22/2010
Michael
http://htluo.blogspot.com
