Can I downgrade AIP-SSM-10 from 6.2(2)E4 to 6.1(2)E3?
Answered Question
May 14th, 2010
I have an AIP-SSM-10 (IPS-K9-6.1-2-E3) running inside an ASA (Active/Standby failover mode).
My license status is "not expired until 12.2010".
When I upgrade to 6.2(2)E4 (because it indicated I needed engine E4 in order to put the signature update) my license changed to expired.
Here is my question, what versions can i upgrade to?
I made a mistake? Can i downgrade to 6.1(2)E3 and in what way?
Thank you
Correct Answer by Jennifer Halim about 6 years 11 months ago
Try deleting the license from service account first, then update the license via cisco.com:
1) Create a username with service account: username password privilege service
2) Then SSH to the IPS with the service account username and password created above.
Then following the steps below:
- "su" to root (same PW as svc acct PW)
- delete all the files in the /usr/cids/idsRoot/shared/ directory, *** EXCEPT host.conf file ***
- run "/etc/init.d/cids restart" to restart the IPS apps (or reboot the sensor)
3) From IDM - apply the real license by choosing to update the license via cisco.com.
Hope that resolves the issue.
Overall Rating: 5 (1 ratings)
Jennifer Halim Fri, 05/14/2010 - 01:34
  • Cisco Employee,
If you upgrade it to the latest version, it should not expire the license. You can even upgrade it to the latest version of 7.0.2(E4).
Try to grab the license again from IDM: Configuration --> Sensor Management --> Licensing --> Update from: cisco.com
You have to make sure that the AIP module management ip has connectivity to the Internet to connect to cisco.com
Hope that helps.
n_ganeva Fri, 05/14/2010 - 01:53
Thank you for the quick response.
I update license from IME: Configuration --> Sensor Management --> Licensing --> Update from: cisco.com
but receive error:
"Failed to update license on sensor.
errExpiredLicense-The new license expire date is older than current license expire date."
In IME-Home - Device Detail-License status for sensor is: "License expired on 2554-7-22 02:34:32 EEST"
but in Device List-License Expiration - status is "License expired"
Thanks in advance!
Correct Answer
Jennifer Halim Fri, 05/14/2010 - 01:59
  • Cisco Employee,
n_ganeva Fri, 05/14/2010 - 02:57
Thank you very much halijenn for the quick response and for help!!!
Your answers was really helpful to me.
When I tried to get new license from cisco.com, I received selfsame license "License expired on 2554-7-22 02:34:32 EEST".
Then I repeated the procedure described by you but I update license from my old receved file from cisco - "signatureupdatekey"
and now license is OK.
Thanks again for your great help!!!
N.Ganeva
Related Content
