SA540 DHCP server multi subnet ISSUE
May 14th, 2010
i have SGE2000 is Core Switch it have 3 vlan
vlan 1 :
vlan 2 :
vlan 3 :
static route / 24 next hop
vlan1 :
static route : next hop
its connect with SA540 in ports 1st no vlan enable i config only static route back to core switch. now i want to use SA540 to assign IP for clients in every vlan it can.
i see vlan function and i enable and create vlan same the SGE2000 and create DHCP scope and disable Inter-vlan routing because i want to use routing cross vlan on SGE2000 , then clients on every can't access to vlan 1 but when i delete vlan on SA540 it ok , clients can access to vlan and can use internet.
have solution for this because i don't have dhcp server and in AP have multiple ssid , i think it must use dhcp because i can't fix ip for wifi clients
thank you for your support.
charlesw Tue, 05/18/2010 - 14:28
Based on your decription and configuration, I am suspecting there might be a routing loop.  Can you remove the static routes and disable the inter-vlan function in the SA to see if you still encounter the same issue?
If issue persists, can you PM your SA and your switch confguration?
Best Regards,
Related Content
