rommon
Answered Question
May 14th, 2010
If a router boots to the prompt rommon1>
does it signify that
the conf file was not found in flash memory OR
IOS image in flash memory is invalid or corrupt?
Correct Answer by Ganesh Hariharan about 7 years 2 months ago
Hi ,
It means that the router cannot find a valid image in the flash memory. The image usually gets corrupted or lost.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Correct Answer by Jon Marshall about 7 years 2 months ago
Peiwai
It can be a number of things but the commonest is that the router didn't find a bootable IOS version. Note an IOS version not the running-config. It can be because it doesn't have an image in flash or more likely that the config register has been set incorrectly.
Jon
Overall Rating: 5 (4 ratings)
Correct Answer
Jon Marshall Fri, 05/14/2010 - 04:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Peiwai
Jon
Correct Answer
Ganesh Hariharan Fri, 05/14/2010 - 04:24
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi ,
Hope to Help !!
Ganesh.H
Leo Laohoo Sun, 05/16/2010 - 02:58
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
1.  Your config-register tells the appliance to boot into ROMmon;
2.  Someone performed the intial password recovery (Ctrl+Break) or hold the Mode button during power up;
3.  In routers with no boot statement:  The first image is either corrupted or an invalid image;
4.  In routers with boot statement:  IOS file is not found; and
5.  In old switches, the boot statement is wrong or no IOS file found
kenlee1978 Sun, 05/16/2010 - 07:07
Basically it is the basic boot to the IOS. Like what Leo mentioned, you can break it or if the IOS is corrupted, you will get to this problem too.
