RSPAN on 3750 - getting only rx traffic
May 14th, 2010
I'm doing rspan between two 3750G connected  by trunk on etherchannel running  version 12.2(44)SE5.
I only get receive traffic from the remote span vlan. I have create the remote span vlans and allowed it on the trunk interface on both sides.
Switch 1
Session 1
Type                   : Remote Source Session
Source Ports           :
    Both               : Gi1/0/17
Dest RSPAN VLAN        : 4094
monitor session 1 source interface Gi1/0/17
monitor session 1 destination remote vlan 4094
Switch 2
Session 1
Source Ports           :
    Both               : Gi1/0/17
Session 2
Type                   : Remote Destination Session
Source RSPAN VLAN      : 4094
Destination Ports      : Gi1/0/27
    Encapsulation      : Native
          Ingress      : Disabled
monitor session 2 destination interface Gi1/0/27
monitor session 2 source remote vlan 4094
If I do local span then I get all the  transmit/receive traffic from the source interface.
Thanks.
Overall Rating: 5 (1 ratings)
jbrenesj Tue, 05/18/2010 - 08:03
Pretty much what you are trying to do is RSPAN the same switch´s traffic tying to fool the switch to send it´s own interface traffic to the rspan vlan and then capture it again with another monitor session. Unfortunately this is not possible.
I have seen it working a couple of times but you will get unexpected results.
It looks like you´ll need a third switch for this task.
- Jorge
satendrak Sat, 08/14/2010 - 02:53
I have added a third switch 3750-24P running 12.2(46)SE and trunked to my switch1 allowing RSPAN VLAN 4094 on the trunk. Now my issue is the destination port on switch3 does not receive any traffic, I see taffic coming in on the trunk interface.
switch3#sh monitor
Session 1
Destination Ports      : Fa1/0/1
          Ingress      : Disabled
Trunk:
switchs3#sh int fa1/0/24
FastEthernet1/0/24 is up, line protocol is up (connected)
  30 second input rate 3019000 bits/sec, 614 packets/sec
  30 second output rate 3000 bits/sec, 4 packets/sec
Destination port:
switch3#sh int fa1/0/1
FastEthernet1/0/1 is down, line protocol is down (monitoring)
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
monitor session 1 destination interface Fa1/0/1
monitor session 1 source remote vlan 4094
Any ideas what am I missing here?
satendrak Sat, 08/14/2010 - 18:53
Output from both switches below:
switch1#sh vlan remote-span
Remote SPAN VLANs
4094
switch3#sh vlan remote
Remote SPAN VLANs
4094
Thanks.
Nagaraja Thanthry Sat, 08/14/2010 - 19:06
Can you try removing the local span session that sends traffic to remote
VLAN and see if that helps?
NT
satendrak Sat, 08/14/2010 - 19:38
Since the addition of switch3, switch 1 and 2 only have the following configured:
cheers
satendrak Sat, 08/14/2010 - 19:58
Yes it has, as in one of replies above:
Remote SPAN VLANs
4094
rcongani Mon, 11/08/2010 - 13:58
Hello Satendark,
What you are seeing is expected behavior with the folllowing configurations, this is a limitation on 3750
You cannot copy local source  gig 1/0/17 traffic to rpsan vlan and again create a another monitor session copying that traffic to destination on the same source switch. This can be done on 6500 series switches.
But there is a hack, here is waht you need to do.
( you dont need the second monitor session )
Rspan traffic is flooded on trunks , so you can configure the sniffer port ( destination port Gi1/0/27 as following.)
interface  Gi1/0/27
switchport trunk native vlan 4096
switchport mode trunk
switchport trunk allowed vlan 4096
spanning-tree portfast trunk
You will see all your trafffic.
Thanks and let me know how it goes.
Ruvin
Related Content
