05-14-2010 04:51 AM - edited 03-11-2019 10:45 AM
Dear All,
I am having two cisco 6513 switch and configured HSRP in the switch.Each switch having the FSM Module(i.e for Active/Standby).
I have uploaded
1.asdm-621f.bin
2.c6svc-fwm-k9.3-2-17.bin
that file in my supbootdisk as well as supbootflash..Can any one tell me, what i have to do for getting GUI of FSM Module.Is anything to be uploaded or anything to be configured initially?
Thanks in Advance
Senthil
05-14-2010 05:01 AM
Assuming that from "show version" output, you have the ASDM 6.2.1F listed, and you have configured basic vlan assignment for the FWSM through the switch, and configured ip address on the vlan, then you only need to enable the http server as follows:
http server enable
http
Here is the command reference for the second line of http command for your reference:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm32/command/reference/gh.html#wp1585659
Hope that helps
05-14-2010 06:42 AM
Hi Senthil
In addition to halijenn's comment i would suggest you to check ASDM vs FWSM OS compatibility list to make use of ASDM with FWSM.
http://www.cisco.com/en/US/docs/security/asdm/6_1f/release/notes/rn61f.html#wp315986
Above link gives you the os & asdm version compatibility list.
regds
