6509 high memory usage, any need to be concerned?
May 14th, 2010
I have been reading trough http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/best/practices/recommendations.html before deploying a 6509 VSS, after checking the command "sh platform hardware capacity cpu" i see almost all the memory is in use, while the switch basicly does nothing, it has som switches connected but there is not any traffic.
The documentation states:
Issue the show  platform hardware capacity command periodically to monitor  system resource usage. Any system resource with usage of 90% or greater  should be addressed.
Output from sh platform hardware capacity cpu:
CPU Resources
  CPU utilization: Sw/Mod             5 seconds       1 minute       5 minutes
                    1/1                0% /  6%             0%              1%
                    1/5  RP            2% /  3%             1%              1%
                    1/5  SP            3% /  3%             4%              4%
                    1/7                0% /  1%             0%              0%
                    2/1                0% /  6%             0%              1%
                    2/5  RP            0% /  0%             0%              0%
                    2/5  SP            2% /  2%             4%              4%
                    2/7                0% /  1%             0%              0%
  Processor memory: Sw/Mod   Bytes:       Total           Used           %Used
                     1/1               25165648       24653960             98%
                     1/5  RP           88799456       83598736             94%
                     1/5  SP           94394032       90762536             96%
                     1/7               29359864       25274104             86%
                     2/1               25165648       24672040             98%
                     2/5  RP           84605240       82950992             98%
                     2/5  SP           90199816       89629440             99%
                     2/7               29359864       25216104             86%
  I/O memory: Sw/Mod         Bytes:       Total           Used           %Used
               1/1                      8126344        7886544             97%
               1/5  RP                 12058384       10714264             89%
               1/5  SP                  8388608        8104304             97%
               1/7                      8126344        7886544             97%
               2/1                      8126344        7886544             97%
               2/5  RP                 12058384       10714264             89%
               2/5  SP                  8388608        8104304             97%
               2/7                      8126344        7886544             97%
Output from sh proc mem:
System Memory : 1048576K total, 365989K used, 682587K free, 1000K kernel reserved
Lowest(b)     : 698920960
Could there be a memory leak or is this normal?
IOS Version: Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-VM), Version 12.2(33)SXI3, RELEASE SOFTWARE (fc2)
added sh proc mem info
Giuseppe Larosa Fri, 05/14/2010 - 09:23
Hello Joakim,
memory leak would mean increasing use of memory over time caused by a process not releasing memory resources
but we see that:
your IOS image 12.2(33)SXI3 is considered good for VSS as reported by other colleagues like Reza in other threads
sh proc mem shows
682587 KB free memory
so I would say  that the sh platform hardware capacity cpu may show memory usage of CEF tables rather then main cpu memory usage
I would look at PFC memory and DFC memory on each linecard
how many IP prefixes are present in the system?
sh ip route summary
can tell you this
Hope to help
Giuseppe
mastrboy_ Fri, 05/14/2010 - 09:32
Not much:
# sh ip route summary
IP routing table name is Default-IP-Routing-Table(0)
IP routing table maximum-paths is 32
Route Source    Networks    Subnets     Overhead    Memory (bytes)
connected       0           6           432         864
static          1           1           144         288
internal        5                                   10940
Total           6           7           576         12092
Removing Queue Size 0
usman ali dar Wed, 11/05/2014 - 10:54
hey folks
we have a 6509 and its been constantly working on from 85-96% daily bases can you see the below output and kindly help me understand this out and how can i get this down
regards
 sh hardware capacity
Module Ttlent QoSent RBLent Lbl   LOU  TCP  Dstbl Ethcam ACTtbl V6ext
  1       2%     6%     0%     1%    1%   0%   2%    0%     0%     0%
  6       2%     6%     0%     1%    1%   0%   2%    0%     0%     0%
  8       2%     6%     0%     1%    1%   0%   2%    0%     0%     0%
BA-C154-COR01#sh platform hardware capacity ?
  acl             Show QoS/Security ACL capacity
  cpu             Show CPU resources capacity
  eobc            Show EOBC resources capacity
  fabric          Show Fabric resources capacity
  flash           Show Flash/NVRAM resources capacity
  forwarding      Show forwarding engine capacity
  ibc             show IBC resources
  interface       Show Interface resources capacity
  monitor         Show SPAN resources capacity
  multicast       Show L3 and LTL Multicast resources
  netflow         Show Netflow capacity
  pfc             Show PFC resources capacity
  power           Show Power resources capacity
  qos             Show QoS resources capacity
  rate-limit      Show CPU Rate Limiters capacity
  rewrite-engine  Show rewrite-engine capacity
  system          Show System resources capacity
  vlan            Show VLAN resources capacity
  |               Output modifiers
  <cr>
BA-C154-COR01#sh platform hardware capacity vlan
VLAN Resources
  VLANs: 4094 total, 158 VTP, 153 extended VTP, 71 internal, 3712 free
System Resources
  PFC operating mode: PFC4
  Supervisor redundancy mode: administratively sso, operationally sso
  Switching resources: Module   Part number               Series      CEF mode
                       1        WS-X6824-SFP              CEF720          dCEF
                       2        WS-SVC-WISM2-K9           CEF720           CEF
                       3        WS-X6704-10GE             CEF720           CEF
                       6        VS-SUP2T-10G          supervisor           CEF
                       7        WS-SVC-NAM-2-250S        classic           CEF
                       8        WS-X6848-GE-TX            CEF720          dCEF
Power Resources
  Power supply redundancy mode: administratively redundant
                                operationally redundant
  System power: 3795W, 0W (0%) inline, 2650W (70%) total allocated
  Powered devices: 0 total, 0 Class4, 0 Class3, 0 Class2, 0 Class1, 0 Class0, 0 Cisco
Flash/NVRAM Resources
  Usage: Module Device               Bytes:      Total          Used     %Used
         1      dfc#1-bootflash:              15990784             0        0%
         2      cfc#2-bootflash:              15990784       3610808       23%
         3      cfc#3-bootflash:              32768000             0        0%
         6  RP  nvram:                         2552192        117856        5%
         6  RP  const_nvram:                   1048556         16564        2%
         6  RP  bootdisk:                   1024557056     339574784       33%
         8      dfc#8-bootflash:              15990784             0        0%
CPU Resources
  CPU utilization: Module             5 seconds       1 minute       5 minutes
                   1                  11% /  1%            11%             11%
                   2                   4% /  3%             2%              1%
                   3                   5% /  4%             1%              1%
                   6  RP              96% / 81%            94%             94%
                   8                   9% /  0%            12%             12%
  Processor memory: Module   Bytes:       Total           Used           %Used
                    1                1002567200      202036204             20%
                    2                1002567200       85504916              9%
                    3                 197260960       57244324             29%
                    6  RP            1563624544      263755848             17%
                    8                1002567200      202550648             20%
  I/O memory: Module         Bytes:       Total           Used           %Used
              6  RP                   268435456      110348952             41%
EOBC Resources
  Module                     Packets/sec     Total packets     Dropped packets
  1          Rx:                      31        3189904054                   0
             Tx:                      26         425151314                   3
  2          Rx:                       8        3190197720                   0
             Tx:                       2         203243440                   3
  3          Rx:                      10        3190201752                   0
             Tx:                       5         225185037                   3
  6  RP      Rx:                     139        1573214168                   0
             Tx:                     142        1612182916                   0
  8          Rx:                      49        3189834076                   0
             Tx:                      44         475351872                   3
VLAN Resources
L2 Forwarding Resources
           MAC Table usage:   Module  Collisions  Total       Used       %Used
                              1                0 131072      10723          8%
                              6                0 131072      10901          8%
                              8                0 131072      10960          8%
L3 Forwarding Resources
             FIB TCAM usage:                     Total        Used       %Used
                  72 bits (IPv4, MPLS, EoM)     262144        5254          2%
                 144 bits (IP mcast, IPv6)      131072         348          1%
                 288 bits (IPv6 mcast)           65536          46          1%
                     detail:      Protocol                    Used       %Used
                                  IPv4                        5253          2%
                                  MPLS                           0          0%
                                  EoM                            1          1%
                                  IPv6                           4          1%
                                  IPv4 mcast                   344          1%
                                  IPv6 mcast                    46          1%
            Adjacency usage:                     Total        Used       %Used
                                               1048576       37189          4%
     Forwarding engine load:
                     Module       pps   peak-pps                     peak-time
                     1         163793     788843  13:52:42 EDT Tue Sep 9 2014
                     6         745649    1216821  16:51:37 EDT Sun Aug 17 2014
                     8          22802     198500  11:09:10 EDT Wed Sep 3 2014
Netflow resources:
  Netflow table size: 515032 entries total
  Netflow table usage: Module/Instance    Input flows    Output flows
                             1                 0%              0%
                             6                 0%              0%
                             8                 0%              0%
  Profile/Flowmask allocation:
      IPv4: total 32, used/reserved 5, available 27
          ID        Feature
           0          FM
           1          FM
          29          NDE
          30          NDE
          31          FM
      IPv6: total 32, used/reserved 4, available 28
          ID        Feature
           0          FM
           1          FM
          30          NDE
          31          NDE
      MPLS: total 8, used/reserved 4, available 4
          ID        Feature
           0          FM
           5          QOS
           6          QOS
           7          QOS
      L2: total 8, used/reserved 3, available 5
          ID        Feature
           0          FM
           1          FM
           7          FM
  Sampler allocation: total 1024, used/reserved 1, available 1023
  Copy sampler allocation: total 8, used/reserved 1, available 7
CPU Rate Limiters Resources
             Rate limiters:       Total         Used      Reserved       %Used
                    Layer 3          31            2             0          6%
                    Layer 2 Input    20            9             5         45%
                    Layer 2 Output    6            0             0          0%
Classification Mgr Tcam Resources
  Key: Ttlent - Total TCAM entries, QoSent - QoS TCAM entries, LOU - LOUs,
       RBLent - RBACL TCAM entries, Lbl - Labels, TCP - TCP Flags,
       Dstbl  - Destinfo Table, Ethcam  - Ethertype Cam Table,
       ACTtbl - Accounting Table, V6ext - V6 Extn Hdr Table
L3 Multicast Resources
  Replication mode: egress
  Bi-directional PIM Designated Forwarder Table Capacity: 8  Per Vrf
  Bi-directional PIM Designated Forwarder Table usage:
    Vrf                                IPV4 used  IPV6 used  Total used
    Default                            1          0          1  (12 %)
  Replication capability: Module                            Capability
                          1                                 egress
                          2                                 egress
                          3                                 egress
                          6                                 egress
                          7                                ingress
                          8                                 egress
  MET table Entries: Module                             Total    Used    %Used
                     1                                  65518     358       1%
                     6                                  32752     110       1%
                     8                                  65518     248       1%
QoS Policer Resources
  Aggregate policers: Module                      Total         Used     %Used
                      1                           16384            2        1%
                      6                           16384            2        1%
                      8                           16384            2        1%
  Microflow policer configurations: Module        Total         Used     %Used
                                    1               128            1        1%
                                    6               128            1        1%
                                    8               128            1        1%
  Netflow policer configurations: Module          Total         Used     %Used
                                    1               384            0        0%
                                    6               384            0        0%
                                    8               384            0        0%
  Aggregate policer configurations:    Module     Total         Used     %Used
                                       1           1024            2        1%
                                       6           1024            2        1%
                                       8           1024            2        1%
  Distributed policers: Total          Used     %Used
                          4096            1         1%
  QoS Tcam Entries: Module                        Total         Used     %Used
                    1                             16384         1034        6%
                    6                             16384         1034        6%
                    8                             16384         1034        6%
Switch Fabric Resources
  Bus utilization: current: 38%, peak was 74% at 16:59:07 EDT Sun Aug 17 2014
  Fabric utilization:     Ingress                    Egress
    Module  Chanl  Speed  rate  peak                 rate  peak
    1       0        20G    7%   22% @10:42 28Oct14    3%   27% @04:00 13Aug14
    2       0        20G    2%   10% @12:17 29Oct14    0%    5% @09:06 27Oct14
    3       0        20G    0%   15% @04:40 17Aug14    0%   23% @16:02 17Aug14
    3       1        20G    7%   22% @14:31 14Aug14    0%   10% @23:13 11Oct14
    6       0        20G    7%   57% @16:02 17Aug14    7%   17% @14:09 29Oct14
    6       1        20G    2%    5% @10:24 04Nov14   18%   48% @16:02 17Aug14
    8       0        20G    0%    7% @08:32 23Sep14    0%    3% @09:28 05Nov14
    8       1        20G    0%    2% @11:06 26Sep14    0%    3% @09:28 05Nov14
  Switching mode: Module                                        Switching mode
                  1                                                       dcef
                  2                                                       acef
                  3                                                       acef
                  6                                                        bus
                  8                                                       dcef
Interface Resources
  Interface drops:
    Module    Total drops:    Tx            Rx      Highest drop port:  Tx  Rx
    7                 2866334516             0                           7   0
    8                   10252753             0                          15   0
  Interface buffer sizes:
    Mod/Port                      Bytes:  Tx buffer       Rx buffer
    1/1                                     1221184          173952
    1/2                                     1221184          173952
    1/3                                     1221184          173952
    1/4                                     1221184          173952
    1/5                                     1221184          173952
    1/6                                     1221184          173952
    1/7                                     1221184          173952
    1/8                                     1221184          173952
    1/9                                     1221184          173952
    1/10                                    1221184          173952
    1/11                                    1221184          173952
    1/12                                    1221184          173952
    1/13                                    1221184          173952
    1/14                                    1221184          173952
    1/15                                    1221184          173952
    1/16                                    1221184          173952
    1/17                                    1221184          173952
    1/18                                    1221184          173952
    1/19                                    1221184          173952
    1/20                                    1221184          173952
    1/21                                    1221184          173952
    1/22                                    1221184          173952
    1/23                                    1221184          173952
    1/24                                    1221184          173952
    3/1                                    14622592         2064768
    3/2                                    14622592         2064768
    3/3                                    14622592         2064768
    3/4                                    14622592         2064768
    6/1                                     8640576        10127232
    6/2                                     8640576        10127232
    6/3                                     8640576        10127232
    6/4                                    91887104       109293504
    6/5                                    91887104       109293504
    8/1                                     1221184          173952
    8/2                                     1221184          173952
    8/3                                     1221184          173952
    8/4                                     1221184          173952
    8/5                                     1221184          173952
    8/6                                     1221184          173952
    8/7                                     1221184          173952
    8/8                                     1221184          173952
    8/9                                     1221184          173952
    8/10                                    1221184          173952
    8/11                                    1221184          173952
    8/12                                    1221184          173952
    8/13                                    1221184          173952
    8/14                                    1221184          173952
    8/15                                    1221184          173952
    8/16                                    1221184          173952
    8/17                                    1221184          173952
    8/18                                    1221184          173952
    8/19                                    1221184          173952
    8/20                                    1221184          173952
    8/21                                    1221184          173952
    8/22                                    1221184          173952
    8/23                                    1221184          173952
    8/24                                    1221184          173952
    8/25                                    1221184          173952
    8/26                                    1221184          173952
    8/27                                    1221184          173952
    8/28                                    1221184          173952
    8/29                                    1221184          173952
    8/30                                    1221184          173952
    8/31                                    1221184          173952
    8/32                                    1221184          173952
    8/33                                    1221184          173952
    8/34                                    1221184          173952
    8/35                                    1221184          173952
    8/36                                    1221184          173952
    8/37                                    1221184          173952
    8/38                                    1221184          173952
    8/39                                    1221184          173952
    8/40                                    1221184          173952
    8/41                                    1221184          173952
    8/42                                    1221184          173952
    8/43                                    1221184          173952
    8/44                                    1221184          173952
    8/45                                    1221184          173952
    8/46                                    1221184          173952
    8/47                                    1221184          173952
    8/48                                    1221184          173952
IBC Resources
  6  RP      Rx:                   90948      160807019625                   1
             Tx:                   92221      178588757499                   0
SPAN Resources
  Source sessions: 16 maximum, 2 used
    Type                             Max      Used
    Local                              2(*)      2
    Local-tx                          14         0
    RSPAN source                       2(*)      0
    ERSPAN source                      2(*)      0
    Capture                            1(*)      0
    Service module                     1(*)      0
    OAM loopback                       1(*)      0
    Reflector                          1(*)      0
      * - shared source sessions and the total can not exceed 2
  Destination sessions: 64 maximum, 0 used
    Type                             Max      Used
    RSPAN destination                 64(*)      0
    ERSPAN destination                23(*)      0
      * - shared destination sessions and the total can not exceed 64
Multicast LTL Resources
  Usage:   38848 Total, 835 Used
Related Content
