05-14-2010 06:23 AM - edited 03-04-2019 08:29 AM
If configuring WCCP v2 on a router, how many hops away can the Websense servers be?
Thanks for your help
Kevin
Solved! Go to Solution.
05-14-2010 09:33 AM
Hello Kevin,
for efficient forwarding the web cache should be directly connected to a router interface (in the same IP subnet of a router interface)
on routers you have the option to use GRE encapsulation to send and receive traffic but this is clearly less efficient then L2 forwarding and it may be not available on multilayer switch platforms or other like ASR
see
when using GRE you can use whatever number of hops given that intermerdiate nodes know how to route the GRE packet destination(s) in both directions.
Hope to help
Giuseppe
05-14-2010 09:33 AM
Hello Kevin,
see
Hope to help
Giuseppe
05-17-2010 03:15 AM
That is great, very helpful
Cheers
Kevin
