Can you have a user in a group that is allowed to authenticate via SecurID and also LDAP within ACS ?
May 14th, 2010
Basically we have a group of Users that support multiple accounts, however, one of the accounts require to be authenticated via SecurID.  That leaves the other couple of accounts being authenticated via LDAP.  However, if the Users in that group require access to all accounts how will they authenticate when they can only belong to one group ?
Cheers
Florrie
Jatin Katyal Sun, 05/16/2010 - 22:12
This seems not to be possible with in ACS, if this is what you are trying to configure for VPN user using ASA so that user can authenticate via SECUREID and authorised via LDAP then you can directly integrate ASA with secureID and LDAP without using ACS.
Regds,
JK
Do rate helpful posts-
Dale Kenneth Sheils Thu, 09/30/2010 - 09:32
Since I can use a ASA to authenicate both thru SecurID and LDAP. Where can I configure the double authenication on the ASA?
I am sure I used the cli awhile back and configured SecurID and AD, and it worked, however, the customer decided not to use AD and
I am afraid I forgot the cli command?
