voice and data vlans
Answered Question
May 14th, 2010
Hi Experts
I am new to voice need assistance
My scenario
I have a HP3500 curve in production
it has port 10 defined in data vlan 301 and
         port 12 defined in voice vlan 310
so i connected port 10 on HP 3500- port 1 on cisco 3650 switch
                      port 12 on HP 3500 - port 2 on cisco 3650 switch
what configuration is required on port 1 and port 2 on cisco 3650 switch
and the configuration on rest of the ports where the pcs or ip phones will go.
Asif
Correct Answer by Rick Arps about 6 years 10 months ago
Set your port 1 to access vlan 301
Set your port 2 to access vlan 310
Set every other port to access vlan 301 and have a voice vlan of 310
That should look like:
int fa0/1
description Data VLAN uplink
switchport mode access
switchport access vlan 301
int fa0/2
description Voice VLAn uplink
switchport access vlan 310
int range fa0/3 - 48
description User Access Ports
switchport voice vlan 310
Hope this helps
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Rick Arps Thu, 05/27/2010 - 06:22
  • Bronze, 100 points or more
int fa0/1
int fa0/2
Hope this helps
Rick
akhanwaterloo Fri, 05/28/2010 - 08:49
Thanks that explains very clearly
a quick question
i have 3650 with gig ports then this should be
int gig0/1 or the fa0/1 can also be used
Asif
Rick Arps Fri, 05/28/2010 - 10:52
Yeah, if it's a 3560G switch use G0/x instead of Fa0/x
Rick
