Extension Mobility Timeout Per Phone?
Answered Question
May 14th, 2010
Is there anyway in CUCM 7.1.3 to set a particular phone to not have an extension mobility logout timer, different from the settings in the service parameters?  Are all extension mobility logout settings global?  thanks
Correct Answer by David Hailey about 6 years 10 months ago
Global parameter.  Applies cluster-wide to all EM-enabled phones.
Hailey
Overall Rating: 4.3 (3 ratings)
Correct Answer
David Hailey Fri, 05/14/2010 - 16:12
  • Purple, 4500 points or more
Hailey
asafayan Wed, 12/19/2012 - 08:52
Hi David / Java,
Old thread but I thought I would give it a try.  I need to mod this EM Servive Parameter.  Is it service impacting to any existing users who are logged in via EM?
TIA,
Amir
Jaime Valencia Wed, 12/19/2012 - 08:56
  • Cisco Employee,
  • Hall of Fame,
    2011
No, but changes will only affect phones that log in AFTER you change the value.
Phones that were logged before, will not take that change.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
M.Kemal YENIGUN Wed, 07/31/2013 - 03:54
Hi Java,
Could you please point me where I can find that " Global parameter.  Applies cluster-wide to all EM-enabled phones."
Rob Huffman Wed, 07/31/2013 - 05:46
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi there,
You will find those settings via;
To set the Service Parameters for Cisco Extension Mobility, choose
System > Service Parameters in Cisco  Unified Communications Manager Administration;
choose the server that  is running the Cisco Extension Mobility service, and then  Cisco Extension Mobility
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
