voice and data vlans config
Answered Question
May 14th, 2010
Hi Experts
I am new to voice need assistance
My scenario
I have a HP3500 curve in production
it has port 10 defined in data vlan 301 and
         port 12 defined in voice vlan 310
so i connected port 10 on HP 3500- port 1 on cisco 3650 switch
                      port 12 on HP 3500 - port 2 on cisco 3650 switch
what configuration is required on port 1 and port 2 on cisco 3650 switch
and the configuration on rest of the ports where the pcs or ip phones will go.
Asif
Correct Answer by antonio.rubio about 6 years 8 months ago
What is the idea of connectingthe HP switch to the Cisco switch?  I want to assume that you want to extend the data and voice vlans using the cisco switch,  you need to make sure this are trunks and not access ports.   Access ports are to connect end user equipment and trunks to connect to another switch.  Also, make sure you cabling is correct, when connecting switch to switch most old systems need crossover cables.
Antonio
Overall Rating: 5 (1 ratings)
Ganesh Hariharan Fri, 05/14/2010 - 10:35
Hi Experts
My scenario
Asif
Asif,
Check out the below link for configuring voice vlan on switch for ip phones and for normal vlan configuration on switches also
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Correct Answer
antonio.rubio Fri, 05/14/2010 - 14:21
Antonio
