Voice Quality Degraded, Call Drops.
Mar 11th, 2009
I have CUCME 7.0 on 2811 router with 8 isdn lines.
From past one weeks time users are facing a voice quality problem and when i enabled the debug ISDN q931 on the router i have noticed error keep repeating " unassigned number /un allocated number "
And also when i enable i have noticed this error " Mar 12 06:14:41.867: ISDN BR0/2/1 Q921: User RX <- SABMEp sapi=0 tei=0
Mar 12 06:14:41.867: ISDN BR0/2/1 Q921: User TX -> UAf sapi=0 tei=0
Mar 12 06:14:42.575: ISDN BR0/2/1 Q921: User RX <- SABMEp sapi=0 tei=0
Mar 12 06:14:42.575: ISDN BR0/2/1 Q921: User TX -> UAf sapi=0 tei=0
Mar 12 06:14:42.851: ISDN BR0/2/1 Q921: User RX <- SABMEp sapi=0 tei=0
Mar 12 06:14:42.851: ISDN BR0/2/1 Q921: User TX -> UAf sapi=0 tei=0"
And also
Mar 12 04:49:30.935: ISDN BR0/2/1 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
BARCELONA_CME#
Mar 12 04:58:16.729: ISDN BR0/1/1 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
BARCELONA_CME#
Mar 12 05:25:00.381: ISDN BR0/2/1 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
BARCELONA_CME#
Mar 12 05:26:08.893: ISDN BR0/2/1 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
Mar 12 05:26:08.901: ISDN BR0/2/1 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
BARCELONA_CME#sh clock
06:47:32.474 cdt Thu Mar 12 2009
BARCELONA_CME#
Mar 12 05:56:06.039: ISDN BR0/1/1 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
I have noticed there are CRC errors on the all the BRI interfaces.
When i check with the Telecom provider he said there is no problem from his side.
Please suggest me how can i fix this error and improve the voice quality.
I have attached the sh run from my cme.
ARIF
Paolo Bevilacqua Wed, 03/11/2009 - 23:29
Which exact IOS is that ?
You should be able to eliminate almost all CRC errors with "network-clock-select 1 bri 0/2/0" and lower priorities for each BRI in use.
Unrelated to thta, you can simplify the translation-rules by much. When strippinr prexifing, the recall \1 is never necessary.
syedarif25 Wed, 03/11/2009 - 23:45
Thanks for the reply.
When i enable the network-clock-select 1 bri 0/2/0 and 2 bri 0/3/0 etc.
FROM SH RUN
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-participate wic 3
network-clock-select 1 BRI0/2/0
network-clock-select 2 BRI0/0/0
network-clock-select 3 BRI0/1/0
network-clock-select 4 BRI0/1/1
I get this error
Mar 12 06:41:34.731: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller BRI0/2/0
--More--
Mar 12 06:41:41.271: %MARS_NETCLK-3-HOLDOVER: Exiting Holdover for Controller BRI0/2/0
--More--
Mar 12 06:41:48.771: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller BRI0/2/0
what does it mean .
Can you please elaborate a bit on simplifying the translation rule.
ARIF
syedarif25 Wed, 03/11/2009 - 23:51
Sorry forgot to mention the IOS version , perhaps my attachment has the detals.
Here is the IOS version
BARCELONA_CME#sh ver
BARCELONA_CME#sh version
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(20)T, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jul-08 22:01 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
BARCELONA_CME uptime is 1 day, 15 hours, 20 minutes
System restarted at 16:30:49 cdt Tue Mar 10 2009
System image file is "flash:c2800nm-spservicesk9-mz.124-20.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FHK0913F0DS
2 FastEthernet interfaces
8 ISDN Basic Rate interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
ARIF
etmarcof Sun, 09/20/2009 - 12:58
Have you solved your problem?
If yes, how do you solve it?
Best Regards,
MC
Paolo Bevilacqua Sun, 09/20/2009 - 13:02
The holdover messages reported above are normal when using BRI and network-clock-select. They do not indicate any problem at all.
If you have a new problem, open a new thread.
