vsl link
May 14th, 2010
Last week i had the chance to test two 6506 in vss mode.
I made the steps until i got one good virtual switch running.
My first test was to remove the VSL link to see how it goes...
the switches tell me that they were running simplex mode.
I plugged back the vsl link and nothing happened..
they never detected that the vsl link was plugged
i have reloaded both switches several times and never got
back my virtual switch.... always saying  vsl link down
if you can help me on this,
thanks
Reza Sharifi Fri, 05/14/2010 - 12:55
You are in dual active mode.  Do you have 2 VSL links?
what is the output of "sh swi vir role"?
If you correctly configure VSS and unplug the 2 VSL links after connecting them back the primary switch supposed to reboot.
Reza
desrochj1 Fri, 05/14/2010 - 12:59
right after i made the vss setup, i had one active and one standby
then i unplug vsl and when i reconnected the vsl link 5 minutes later
sh swi vir role showed only 1 active switch and nothing else... no standby
i never saw switch reboot
Reza Sharifi Fri, 05/14/2010 - 13:05
If you have configured it correctly the primary should reboot right away after plugging the VLS back into the switch.  BTW, the reboot takes about 8 minutes.  I actually measured it
desrochj1 Fri, 05/14/2010 - 13:10
i have made the basic setup for VSS
no dual active detection and no recovery setup.
any ideas ?
