05-14-2010 02:20 PM - edited 03-06-2019 11:06 AM
I am having an issue at one of my sites with DHCP. It seems that random machines will fall off the map and their phones as well until they are rebooted and get a new address.
Has anyone seen this before?
May 14 14:15:58.330 PDT: DHCPD: Seeing if there is an internally specified pool class:
May 14 14:15:58.330 PDT: DHCPD: htype 1 chaddr 001e.3748.fd5e
May 14 14:15:58.330 PDT: DHCPD: remote id 020a00000a4223fe2000000a
May 14 14:15:58.330 PDT: DHCPD: circuit id 00000000
May 14 14:16:00.670 PDT: DHCPD: Seeing if there is an internally specified pool class:
May 14 14:16:00.670 PDT: DHCPD: htype 1 chaddr 0009.6ba7.aea7
May 14 14:16:00.670 PDT: DHCPD: remote id 020a00000a4223fe2000000a
May 14 14:16:00.670 PDT: DHCPD: circuit id 00000000
May 14 14:16:07.671 PDT: DHCPD: Seeing if there is an internally specified pool class:
May 14 14:16:07.671 PDT: DHCPD: htype 1 chaddr 0009.6ba7.aea7
May 14 14:16:07.671 PDT: DHCPD: remote id 020a00000a4223fe2000000a
May 14 14:16:07.671 PDT: DHCPD: circuit id 00000000
ip dhcp excluded-address 10.xx.35.250 10.xx.35.254
ip dhcp excluded-address 10.xx.35.120 10.xx.35.126
ip dhcp ping packets 0
ip dhcp pool Voice
network 10.xx.35.0 255.255.255.128
option 150 ip 10.xx.1.10 10.xx.1.15
default-router 10.xx.35.126
dns-server 10.xx.4.206 10.xx.4.208 139.142.2.3 66.244.223.130
ip dhcp pool Workstations
network 10.xx.35.128 255.255.255.128
default-router 10.xx.35.254
domain-name chgfe.biz
rt-3825-1#sh ip dhcp conflict
IP address Detection method Detection time VRF
10.xxxx.3 Gratuitous ARP May 14 2010 12:15 AM
10.xx.35.51 Gratuitous ARP May 14 2010 12:16 AM
10.xx.35.131 Gratuitous ARP May 14 2010 08:45 AM
10.xx.35.132 Gratuitous ARP May 14 2010 08:47 AM
10.xx.35.134 Gratuitous ARP May 14 2010 09:12 AM
10.xx.35.137 Gratuitous ARP May 14 2010 10:25 AM
10.xx.35.138 Gratuitous ARP May 14 2010 12:07 PM
10.xx.35.139 Gratuitous ARP May 14 2010 12:07 PM
10.xx.35.140 Gratuitous ARP May 14 2010 12:07 PM
10.xx.35.141 Gratuitous ARP May 14 2010 12:07 PM
10.xx.35.144 Gratuitous ARP May 14 2010 12:08 PM
10.x.35.146 Gratuitous ARP May 14 2010 02:03 PM
05-18-2010 02:13 AM
If you do:
clear ip dhcp conflict
does it solve the problem?
I think the issue is with the gratuitous arp. Look what I have found:
A Cisco router will send out a gratuitous ARP message out of all interfaces when a client connects and negotiates an address over a PPP connection. However, by default, gratuitous ARP messages are not sent out when the client receives the address from the local address pool. The ip gratuitous-arps non-local command option is the default form and is not saved in the running configuration.
http://www.cisco.com/en/US/docs/ios/12_3/ipaddr/command/reference/ip1_s1g.html#wp1080936
Let me know if this helps you somehow!
