UC520 Incoming Fax Problem
May 14th, 2010
We have a UC520 connected to a AT&T SIP trunk and have a fax machine connected to one of the FXS ports.  We are able to send faxes but we can't receive faxes.  Here is what I have in the config file:
voice translation-rule 8
rule 1 /0741/ /0741/
voice translation-profile Fax_Called_8
translate called 8
voice-port 0/0/0
station-id name Fax
station-id number 0741
dial-peer cor list call-fax
member PSTN-fax
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol none
no fax-relay sg3-to-g3
sip
  registrar server expires max 3600 min 3600
  no update-callerid
dial-peer voice 1 pots
corlist incoming call-fax
description ** CCA Analog Fax **
destination-pattern 0741
port 0/0/0
no sip-register
dial-peer voice 3004 voip
description Fax
translation-profile incoming Fax_Called_8
rtp payload-type cisco-codec-fax-ind 98
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
incoming called-number 0741
dtmf-relay rtp-nte
ip qos dscp ef signaling
no vad
dial-peer voice 1010 voip
corlist outgoing call-fax
description ** Outgoing fax call to SIP trunk **
translation-profile outgoing PSTN_Outgoing
destination-pattern [9]T
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1011 voip
preference 1
session target ipv4:xx.xxx.xxx.59:5060
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1110 pots
port 0/0/0
Can anyone see a problem with this config?
Marcos Hernandez Sun, 05/16/2010 - 08:06
  • Blue, 1500 points or more
Do you get a busy tone when calling in? Can you try removing dial-peer 1?
Marcos
reneten20 Mon, 05/17/2010 - 06:50
When calling the fax number (0741) the following happens:
1. The fax machine answers the call,
2. The fax handshake tone begins and then immediately ends for a second,
3. The fax handshake tone begins again for a 10-15 seconds then
4. The fax machines issues a com error.
I'll remove dial peer 1and see what happens.
reneten20 Thu, 05/20/2010 - 12:19
We took out the dial-peer voice 1 pots  and the result is the same (no inbound fax).  The receiving fax machine states - "no fax detected".  Any other suggestions would be helpful.
vcappucc Sun, 05/23/2010 - 17:36
  • Bronze, 100 points or more
Sounds to me that you are having a SIP/2.0 488 isuee, can you please show us the "deb ccsip messages" and "deb ccsip media" when attemping to receive a fax?
To Just give a shoot, I will try the following commands:
en
conf ter
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
end
wr
The Syntax: fax protocol {t38 [nse [force]]   [ls-redundancy value [hs-redundancy value]] [fallback {cisco | none | pass-through {g711ulaw | g711alaw}}]} is documented in http://www.cisco.com/en/US/docs/ios/12_2t/12_2t13/feature/guide/ftsihfax.html#wp1006806
also if the fax rate disable is configured neither the originating nor the terminating gateway can enter into Cisco fax relay mode, T.38 fax relay mode, or fax pass-through mode. The fax rate disable  disables fax transfer support.
thanks,
Victor.-
Related Content
