NSS6000 rebooted now RAID5 wont start
May 14th, 2010
Yesterday our NSS6000 with 4 x 750Gb Sata drives started running very slowly..
we saved config onto flash USB and performed reboot from admin maintainence panel.
the unit came back up, but under storage it says :
LabelRAID LevelSpareSizeStatusAction
RAIDAraid5No----Stopped
I press start and get :
Failed to start RAID
Please check that all components are present
.. all drives are present, and i can inventory them and they are all online.. there are no errors in the logs..
i have now rebooted the unit about 4 times.. all times exactly the same.
I even read on here and reset to factory then restored configuration from USB and rebooted.. no difference..
Our system is running :
Firmware Version1.14-20 (Thu, 18 Dec 2008 11:09:47 +0000)
Hardware RevisionV03
Last Firmware UpgradeThu Dec 18 22:09:47 2008
can anyone give me any ideas how to get this going again without losing data ?
Cheers
Steve
bhcsprl Wed, 05/26/2010 - 10:36
I've got exactly the same problem today, with an NSS4000.
4 x SATA 2Tb WDC-WD20EADS-00S in a RAID5 array.
I received an email alert:
Software RAID monitor detected an array in a degraded state.
Degraded Mode Management is disabled, this array will continue to run in degraded mode.
I checked the web interface and noticed the array was "Stopped". All 4 disks are PASSED and ONLINE.
When i want to start, i also get the message:
Any idea what's going wrong and how to solve this issue quickly without loosing any data ?
(We have backup, but not for the 6Tb of data...)
Thanks in advance.
Bert.
frankzicat Mon, 11/22/2010 - 10:16
Hello
I have a similar problem :after a reboot, RAID 5 is stopped and fail to start
Did you fix your problem without loosing your data ?
Thank you very very much in advance
Frank
bhcsprl Mon, 11/22/2010 - 10:27
No, i didn't found any solution and Cisco support was useless. The only thing they were able to say was to rebuild a new array and restore from backup...
So i lost all data for which i didn't had any backup.
The same problem occured 4 times on 3 different NSS4000 devices... So i recently throw them away to finally buy real professional devices (definetely not Cisco ones !).
Regards.
Bertrand.
