4500-6L-E Sup
May 14th, 2010
i am using 4506 switch connected to 6509 VSS using 2 10G ports on sup 6L-E.operation was working fine.Due to power failure the 4506 got restarted and post reload the uplinks were not coming up so we removed the X2 and einserted again.Both the libnks came up and is working fine but both status an dlink LED are showing Orange(Amber).As per the installation guideline of Sup6l-E status of orange means diagnostic is going on and orange link means port disabled by user but the traffic is flowing properly.The show interface status shows both links connectd with 10G speed and diagostic test passed successfully for Sup module..both ports are conncted in port channle with Pagp protocol..software on the switch is 12.2.(53)SG1..port configuration is
interface Port-channel1
description **** VSS 6509 ****
switchport
switchport trunk native vlan X
switchport mode trunk
interface TenGigabitEthernet1/1
description **** Connected to 6509-1 ****
switchport trunk native vlan x
channel-protocol pagp
channel-group 1 mode desirable
interface TenGigabitEthernet1/2
description **** Connected to 6509-2 ****
can anyone pleas elet me know why the led's are showing amber for Staus and link..
VSS side configuration
description connected to ****4500****
switchport
switchport trunk allowed vlan a,b,c,x
interface TenGigabitEthernetx/1/y
  description ****connected 4500 1/1***
switchport
switchport trunk native vlan 999
switchport trunk allowed vlan 120-126,999
channel-group 201 mode on
interface TenGigabitEthernetx/2/y
  description connected 4500 1/2*******
switchport
please let me know your comment on the same.
Sameer
sameermunj Fri, 05/14/2010 - 22:11
in teh VSS side configuration please consider follwoing changes
switchport
Leo Laohoo Sun, 05/16/2010 - 02:21
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Excuse my ignorant about the 6L supervisor engine, but how come the line "switchport trunk encapsulation dot1q" is missing?
sameermunj Sun, 05/16/2010 - 21:55
hi
i will get it rectified.
one more thing i observed that the config register value was 0x2101 instaed of default 0x2102...will it really make any corelation for the same.
regards
shinepjoseph68 Fri, 08/13/2010 - 00:09
0x2101 will let to boot from the first image from your flash, if there are multiple images avaialble in the flash even if you specify image in the boot system flash: command.
