ASA 5505 configuration for vpn connection
May 15th, 2010
I'm new to Cisco asa devices and I have to have one configure pretty soon. The goal is to have this device perform as vpn router and allow users to connected to remote site. While trying to configure it I ran into some problem, like I can ping its global ip but I cannot get from inside vlan to the internet. The two vlans I have are the once that come with default configuration, and the only things I have changed are inside ip, no dhcp, outside global IP and vpn for remote access. Question is to I have to enable routing between inside and outside vlan or is it come already pre-configured? Do I have to change anything in NAT or access policy. The best thing for me would be if someone could give me sample configuration. I use gui tool to configure it.
Thank You
Jennifer Halim Sat, 05/15/2010 - 19:11
  • Cisco Employee,
From the description, I believe that you would like to configure ASA for VPN Client access.
Here is the sample configuration for VPN Client access:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008060f25c.shtml
If you need to configure LAN-to-LAN VPN tunnel, here is a sample config:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080950890.shtml
Hope that helps.
