SPA504g localization not successful
May 16th, 2010
I try to localize a spa504g phone using the spa9x2 dictionnaries. The sotware version is 7.4.4.
My dictionnary script is :
<!-- Language -->
<Dictionary_Server_Script ua="na">
serv=tftp://172.20.20.1/;
d0=English;x0=enS_US_v615.xml;
d1=French;x1=frS_FR_v615.xml;d2=Italien;x2=itS_v615.xml;
d3=German;x3=deS_v615.xml;
d4=Spanish;x4=esS_ES_v615.xml;
</Dictionary_Server_Script>
On the phone, i can find under the language option these 4 languages but selecting one changes nothing on the phone generate a syslog message when saving the language choice :
SYSLOG kernel.emergency : .<Embedded Msg>:     save param: 464 = 0 465
Is this a bug affecting this software or should the syntax be different ?
philippe.blasut... Fri, 05/21/2010 - 03:01
I had a problem with my tftp server not serving the language file.
It works well with the v615 versions of dictionaries.
I received a v_23_0 version of the french and english dictionnaries for LDAP localization, these files are not recognized by the phone.
Alberto Montilla Fri, 05/21/2010 - 05:00
Hi Philippe;
Can you tellme the complete filename of the v23 files not working on your system?
regards
Alberto
philippe.blasut... Fri, 05/21/2010 - 06:40
Hi Alberto,
It is frS_v_23_0.xml that should fix localization problem on spa9xx for ldap queries.
