UC540 Software Upgrade
May 16th, 2010
Trying to upgrade to new image UC540-8.0.2, and I keep getting an error during the upgrade procedure.  The system is a base unit plus 3 x 525G phones that are connected directly to the unit. The system that has the new image is connected to the network via an ethernet cable is a Windows 7 (64bit) laptop running Cisco Configuration Assistant 2.2(2). Firewalls are off, AV is off and there are no FTP or TFTP services running
Status Messages from the multiple attempts are below, any input would be appreciated
Warning:
While the device is being upgraded with new software, the following
activities should be avoided since they are harmfull and could leave
the device in an unpredictable state:
- Manually access the device CUE module
- Activate a new feature from the left panel
- Cancel software upgrade operation prematurely
Software upgrade for all components requested
Starting to upgrade IOS image...
(Time estimation: 3 minutes)
Uploading the image.
Failed to pass TFTP traffic test between the device and CCA PC.
Software upgrade for one or more components failed.
Software upgrade failed.
Warning:
Determining available space...
Start uploading IOS image...
IOS Upgrade in progress, please wait... (1)
IOS Upgrade in progress, please wait... (2)
IOS Upgrade in progress, please wait... (3)
IOS Upgrade in progress, please wait... (4)
IOS Upgrade in progress, please wait... (5)
Installing new image on the device. Please wait...
Reading new image...
Loading uc500-advipservicesk9-mz.150-1.XA2 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 38008920/4096 bytes]
38008920 bytes copied in 100.828 secs (376968 bytes/sec)
Done upgrading of IOS image
Start to upgrade CME files
(Time estimation: 18 minutes)
Uploading CME phone loads...
CME Files Upload in progress, please wait... (1)
CME Files Upload in progress, please wait... (2)
CME Files Upload in progress, please wait... (3)
CME Files Upload in progress, please wait... (4)
Upload of CME files failed.
Warning:
38008920 bytes copied in 99.960 secs (380241 bytes/sec)
Warning:
IOS Upgrade in progress, please wait... (6)
IOS Upgrade in progress, please wait... (7)
IOS Upgrade in progress, please wait... (8)
IOS Upgrade in progress, please wait... (9)
%Error reading ftp://*****:[email protected]/uc500-advipservicesk9-mz.150-1.XA2 (Connection timed out)
Marcos Hernandez Thu, 05/20/2010 - 07:39
  • Blue, 1500 points or more
Do you happen to have a secondary NIC or wireless connection active during this upgrade?
Marcos
jwaskewics Wed, 08/04/2010 - 15:51
Graham,
Did you ever fix this issue and get upgraded?
We are having the same exact issue right now onsite - ouch....
What is the fix or work around?
