Blade Server/Switch Question
May 16th, 2010
Hi -- a bit confused about something.
If a blade chassis/encosure is going to use the Cisco 3130 blade switch, where does it fit into the overall architecture of the enclosure?
For example, the Dell M-1000e blade enclosure was designed to support Ciscos 3130 blade switches. But how do they fit into the overall architecture  scheme? Normally, the blade servers connect to the I/O fabrics through the passive where does the switch come in? Or does the switch replace the I/O fabrics?
