05-16-2010 06:37 PM - edited 03-15-2019 10:47 PM
Hi expert...
is there anyway to block internal calls on CME?
for example, RouterA extensions 1000,1001 and RouterB extensions 2000,2001.. I want to restrict so 1000 wont be able to call 2000, however 1000 can call 2001
I tried to configure like below, however, I still can call 2000 from 1000
RouterA
dial-peer cor custom
name 2000
dial-peer call list call2000
member 2000
dial-peer voice 2000 voip
corlist outgoing call2000
destination-pattern 2000
session target ipv4:10.0.0.2
codec g711ulaw
dial-peer voice 2001 voip
codec g711ulaw
ephone-dn 1
number 1000
ephone-dn 2
number 1001
corlist incoming call2000
Thanks in advance
Solved! Go to Solution.
05-16-2010 10:32 PM
Hi Torrence,
COR list to work, you need to have both incoming and outgoing corlist on dialpeers.
Now, since ephone-dn 1 (for ext 1000) doesn't have any cor list, it can dial all the other dial-peers
Correct configuration will be like this
name block-pt
name permit-pt
dial-peer cor list block2000
member block-pt
dial-peer cor list permit2000
member permit-pt
corlist outgoing permit2000
codec g711ulaw
codec g711ulaw
ephone-dn 1
number 1000
corlist incoming block2000
ephone-dn 2
number 1001
with this configuration, when 1000 dials 2000, router will check incoming cor list block2000 with outgoing cor list permit2000. Since incoming is not subnet of outgoing call fails.
When 1000 dials 2001. Out going dial-peer does not have any cor list. So, not restriction.
for 1001, no incoming cor list, so outgoing cor list doesn't apply
Hope this helps
thanks
-abu
05-16-2010 10:32 PM
Hi Torrence,
name block-pt
name permit-pt
member block-pt
member permit-pt
codec g711ulaw
codec g711ulaw
ephone-dn 1
number 1000
ephone-dn 2
number 1001
Hope this helps
thanks
-abu
05-17-2010 12:21 AM
it's worked !!
Thanks a lot
