CAT 6500 - WS_SUP32GE-3B redundancy quetion.
May 16th, 2010
Currently we only have one WS-SUP32GE-3B module in slot 5 of out CAT 6500. We have just purchased a second one to put in slot 6.
Currently the module in slot 5 has the following config:
redundancy
keepalive-enable
mode sso
main-cpu
  auto-sync running-config
Once I prepare the new module to run the same IOS version as the existing module in slot 5 and during a maintenance window put the new module in slot 6, with the above config, then the config should sync from the Active module in slot 5 to the Standby modulein slot 6 - right?
Overall Rating: 2 (1 ratings)
Ganesh Hariharan Sun, 05/16/2010 - 23:02
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
redundancy
keepalive-enable
mode sso
main-cpu
Check out the below link for step by step procedure for adding new sup in 6500
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008085a6d3.shtml#concept1
Hope to help !!
Ganesh.H
If helpful do rate the post
Related Content
