Leo Laohoo Sun, 05/16/2010 - 23:49
VLAN and VTP  is NOT Layer 3 routing.  What appliance running CatOS are you talking about?  What's your design.  Judging from your line of questioning you've got everything working against you.
Anjan Kumar Sun, 05/16/2010 - 23:59
i would like to make inter routing between Vlans.....so i dont have any router which supports subinterface with dot.q encapsulation.
thinking.....instead of setting up router on stick i can make it with layer 3 switch.
so what you suggest for this?
thanks
Anjan
Anjan Kumar Mon, 05/17/2010 - 00:20
i dont have appliance...
Actually  my network is having these devices.
1.Cisco 2948G-GE-TX ----1no
2.Cisco 2950 ------3 no
3.Linksys -------4no
4.HP Procurce----5no
i think no where i can configure VTP with non cisco devices, there is only one solution is manual vlans.
can you give me some sugessions ....
Anjan
Leo Laohoo Mon, 05/17/2010 - 00:28
Groan!
Geez.  If you don't need additional ports for the Layer 3 CatOS switch, then I recommend you get a cheap Cisco router to do your dot1q trunking.  The router you need should have FastEthernet or GigabitEthernet WAN ports.
Like I mentioned in my first post, what you are trying to do is a prime candidate for failure.  I have no idea what the Linksys and HP Procurve you are using can/can't do particularly with dot1q trunking.
I do pray that this is not a production network.
Giuseppe Larosa Tue, 05/18/2010 - 02:29
Hello Anjan,
post a sh module of:
a specific routing engine is required to perform intervlan routing it is not only a question of CatOS version.
if that part is missing as suggested by Leo you could go for a 3560 multilayer switch
Hope to help
Giuseppe
Ganesh Hariharan Mon, 05/17/2010 - 00:07
Hi Mates,
i would like to know which cat os supports or devices supports layer 3 routing?
bcoz , i want to make VLan with VTP
Anjan
Anjan,
As suggested by Leo vlan with vtp is normal function of switches it is not related with layer 3 routing, any how checkout the below link on intervakn routing support on cat series switches.Hope that clear your query !!
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bf9a.shtml
Ganesh.H
Arup Dutta Mon, 05/17/2010 - 00:32
Hi Anjan,
             you should go through hardware 3650 to on words.3650 is smart L3 switch.
i hope you will helpfull.
