05-17-2010 01:03 AM - edited 03-20-2019 07:52 PM
Hi Team,
Following Bug id CSCsa62544 says proprietary information that cannot be disclosed at this time,is there any specifc reason !!
Ganesh.H
Solved! Go to Solution.
05-21-2010 06:59 AM
05-18-2010 07:49 AM
Hi Ganesh
My name is Arun Solleti, and i am the Product Manager for Bug Toolkit.
To better assist you with below case, it would be great if you can help me answer below questions:
1) Are you trying to get a VRF aware SSH functionality to work, and looking for right image information ?
2) How did you get awareness about "CSCsa62544" that you tried to see in Bug Toolkit ?
Arun
05-18-2010 11:25 PM
Hi Ganesh
Arun
Hi Arun,
Thanks for the reply !!
For question 1 :- yes
For question :- I got to know via one of the thread where one of the cisco employee as suggested,Just check out the below link:-
https://supportforums.cisco.com/message/965472#965472
Hope to Help !!
Ganesh.H
05-19-2010 03:03 PM
Hi Ganesh
Thanks, now that i know you are looking for an IOS image which has the fix for this bug.
Can you please let me know which platform are you using so that i can find the correct image/train information for you ?
Arun
05-19-2010 11:26 PM
Hi Ganesh
Arun
Thanks Arun !! Here are the details
VRF on 6500/7600 series
7609 -- 12.2(33)SRC3 Advanced IP Services
6509-E switch running 12.2(33)SXH3a Advanced IP Services
Hope to Help !!
Ganesh.H
05-20-2010 03:18 AM
Hi Ganesh,
You can use Feature Navigator tool to find the correct IOS image for the feature VRF aware SSH.
You can use this tool to compare IOS images and their features.
Here is the link for Feature Navigator tool.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
I hope it will help you.
Suresh KC
05-21-2010 12:46 AM
Hi Ganesh,
Suresh KC
Hi Suresh KC,
I can do that it takes time to search with ios trains and if i know it is bug which is related to my query bug tool kit provides the fixed version in single search.
Ganesh.H
05-21-2010 06:59 AM
05-21-2010 11:12 AM
Thanks Arun for reply and useful information about the Bug Detail !!
Ganesh.H
