05-17-2010 03:30 AM
Hi all,
On the ace module, the bandwidth per VIP is a piece of information one can easily get on the cli,
as the below output shows.
sh service-policy VIP_EXAMPLE
Status : ACTIVE
Context Global Policy:
service-policy: VIP_EXAMPLE
class: VIP_CLASS
loadbalance:
L7 loadbalance policy: VIP-EXAMPLE-POLICY
VIP Route Metric : 77
VIP Route Advertise : DISABLED
VIP ICMP Reply : ENABLED
VIP State: INSERVICE
curr conns : 4 , hit count : 1414008981
dropped conns : 6586
client pkt count : 2999321062, client byte count: 1124716083840
server pkt count : 2992929531, server byte count: 1382599949591
conn-rate-limit : 0 , drop-count : 0
bandwidth-rate-limit : 0 , drop-count : 0
I would like to know if this information is also available via SNMP as it is the case for the connection number and connections rate per VIP.
06-07-2010 05:08 AM
That particular info is not currently implemented in an snmp oid. The only way you would be able
to get it into an application would be to do the query using an xml api call
06-23-2010 01:22 AM
thanks for your reply.
Luis Repas
