LMS 3.2 - HUM Data purge question
May 17th, 2010
Hi there,
with reading HUM-Help regarding Data Purge Settings for HUM-DB in LMS 3.2 I'm
not quite sure what and how data is purged in the DB.
We activated the default purging but last weekend we had an blowout within the
UPM-DB (size was approx. 32 GByte).
Does with purging enabled the DB-Filesize shrink?
If no, are there any possibilities shrink filesize of UPM-DB?
Thanks a lot for any feedback.
Lothar
Overall Rating: 3 (1 ratings)
Joe Clarke Mon, 05/17/2010 - 14:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, purging will not shrink database size.  This is true for all LMS purging.  There is a manual process where by the database is unloaded, then reloaded into a clean file.  This will compact it, but the process can take many hours especially on a database so large.  If you want to pursue it, TAC can provide you the steps.
