SMNP trap remove for 2 modules
May 17th, 2010
I have removed 2 modules from my 6509 switch, 1 and 2.  How do I disable the ttraps for just those 2
mods without disabling it for all modules?
David Stanford Mon, 05/17/2010 - 05:47
Are you trying to disable envmon or fru type traps or all traps related to these modules?
SNMP traps are usually global commands, which means they impact all modules/interfaces on a device. If the module isn't there, then traps won't be generated for it.
obrien2010 Mon, 05/17/2010 - 07:59
I think I got it.  The switch generated a trap
when the 2 mods were removed.  My net mon software (Spectrum) pick
ed it up after I removed from maintenance.  Must have been buffered in there.  You are quite correct.  It was only a global command.
