Integration of IronPort into CS-MARS
May 17th, 2010
Can anyone advice how to integrate IronPort into CS-MARS. Thanks.
lekchandmantri Mon, 05/17/2010 - 07:47
Hi halijenn,
Thanks for your prompt response.
I agree, but we can add IronPort as custom device and write custom log parsers for that. I am confused which logs do we need to capture and write parsers as IronPort does not provide message log in one line I mean it break in pieces and maintain MID for each line.
Secondly, I have setup custom device, I received messages but I got "Buffer overflow" error message in IronPort and stop sending logs to CS-MARS.
Can you please advice so as to what could be the cause for this.
I really appreciate if you could advice some interesting things which we can log into CS-MARS from IronPort. Thanks.
Jennifer Halim Tue, 05/18/2010 - 02:24
What logs are IronPort device sending? syslog messages or snmp traps? Generally MARS pretty much just takes syslog and/or snmp. Other types of logging is normally pretty difficult to parse in MARS, and requires complex custom parser to be written.
lekchandmantri Tue, 05/18/2010 - 03:21
I have setup to receive syslog messages from ironport. We configured IronPort to push syslog maillog messages to CS-MARS. It received for a while and it stopped giving error in Ironport something like CSMARS buffer overflow. Below are some messages received from IronPort in CS-MARS.
Parsing error or event type unknown: <22>May 14 12:47:35 MailLog_CSMARS: Info: Message done DCID 61561334 MID 102046326 to RID [1, 2, 3, 4]
Parsing error or event type unknown: <22>May 14 12:47:36 MailLog_CSMARS: Info: MID 102046330 interim AV verdict using Sophos CLEAN
Can you check if anyone has implemented? Thanks.
Related Content
