HP mini-GBIC with Cisco switch
Answered Question
May 17th, 2010
I heard it was possible to use HP mini-GBIC modules with Cisco switches, but there is a special command for it.. Has anybody heard anything about it?
Correct Answer by Tom Randstrom about 6 years 9 months ago
Caveat emptor.
Cisco has indicated they do not support the installation of non-Cisco transceiver modules within their equipment.  They have a unique identifier code stored in the transceiver's memory that is checked by the software during bootup.
As with anything, people work had to get around the systems.  Just remember that if you upgrade the switches software in the future, the hack may no longer work and a new hack will need to be worked.
Overall Rating: 5 (1 ratings)
Leo Laohoo Mon, 05/17/2010 - 06:26
You heard wrong.  It won't work.
Google it.  You'll find it but don't expect forum members to provide you the answer because it ain't ethically correct.
Correct Answer
Tom Randstrom Mon, 05/17/2010 - 06:40
Caveat emptor.
