05-17-2010 07:06 AM
Hi all,
I have a setup with 2 X WAE-7371 devices. my application is SnapMirror.
I have 2 questions,
1.can i used application acceleration mode for that application or i need to use replication mode ? (i understand that i can use both, but what is more recommended ?)
2.for the replication mode, what software is recommended ?, i know that 4.0.19 supported that feature but i cannot download it. can i used 4.0.27 ? (i cannot find configuration guide for that release).
appriciate your help.
Solved! Go to Solution.
05-17-2010 07:14 AM
In this case, you should use the devices in Replication Accelerator mode.
Zach
05-17-2010 07:09 AM
Avi,
1. What are the WAN characteristics (bandwidth and RTT latency) in your environment?
2. The Replication Accelerator mode is supported in the 4.0.x versions of WAAS. You can download and use the latest version from CCO.
Zach
05-17-2010 07:13 AM
i am having an 2 X STM-1 links, pretty much without delay issues.
i am trying to achieve traffic utilization via the DRE\caching mechanism.
05-17-2010 07:14 AM
Zach
