05-17-2010 07:47 AM - edited 03-15-2019 10:47 PM
Hello All,
I´m trying to make a private voice network, in which the central point is an IOS Router with GK and the edges are IOS Routers with H323 to the GK and QSIG to the edge PBXs.
Then, I see that the call from the PBX goes into the QSIG, but the edge IOS router seems to not forward it to the H323 dial-peer.
Any help?
This are the configs:
GK**********************************************
gatekeeper
zone local R6-2611 telecor.es
zone prefix R6-2611 202... gw-priority 10 R2-2811
zone prefix R6-2611 405... gw-priority 10 R3-3825
gw-type-prefix 1#*
no shutdown
EDGE ROUTER *****************************
interface Loopback0
ip address 172.31.1.2 255.255.255.255
h323-gateway voip interface
h323-gateway voip id R6-2611 ipaddr 172.30.253.253 1719
h323-gateway voip h323-id R2-2811@telecor.es
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr 172.31.1.2
dial-peer voice 1 pots
destination-pattern 1#202....
incoming called-number .......
direct-inward-dial
port 1/0/0:15
prefix 202
no register e164
dial-peer voice 20 voip
destination-pattern .......
session target ras
tech-prefix 1#
codec g729r8 bytes 50
The call tested is like:
Calling -- 202AAAA
Called -- 405BBBB
Many thanks
05-20-2010 04:13 PM
Your configuration seems ok on this Edge router. I guess you have similar on the other side. Can upload other Edge router config too?
Also, are they GWs registered to GK?
"show gateway" on the gateway and "show gatekeeper endpoint" on the GK will help to determine that.
If all seems ok, then time to look some debug
GW debug(both):
debug isdn q931
debug h225 asn1
GK debug
debug gatekeeper main 10
debug h225 asn1
- abu
05-21-2010 12:58 AM
Thanks for your help.
This is the other EDGE ROUTER CONFIG*************************
interface Loopback0
ip address 172.31.1.3 255.255.255.255
h323-gateway voip h323-id R3-3825@telecor.es
h323-gateway voip bind srcaddr 172.31.1.3
interface Serial0/1/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-qsig
isdn overlap-receiving
isdn network-failure-cause 34
isdn incoming-voice voice
isdn send-alerting
no cdp enable
voice-port 0/1/0:15
cptone DE
destination-pattern 1#405....
direct-inward-dial
port 0/1/0:15
prefix 405
no register e164
destination-pattern 202....
session target ras
tech-prefix 1#
gateway
timer receive-rtp 1200
"show gateway" and "show gatekeeper endpoint" show at edges and gk that the gateways are registered.
If I use "debug q931" in the edge that receives the QSIG call, I see that the answer from the edge to the pbx is "Unallocated number"
If I use "debug h225 asn1" in the same router for the same call, I see only registration request to the GK and registration confirms from the gk, but nothing about the call.
It seems dial-peer voice 20 voip is no aplying.
What do you think?
05-21-2010 04:45 AM
Once the first problem is solved (mistakes in the dial-peer digits), it seems that I have a problem in the GK, that can not find the destination gateway.
The error is "rejectReason calledPartyNotRegistered", but I see the gateway with the destination number registered. Any help?
This is the usefull info for this:
R6-2611#show running-config
gatekeeper
zone local R6-2611 test.es
zone prefix R6-2611 200* gw-priority 10 R2-2811
zone prefix R6-2611 405* gw-priority 10 R3-3825
no shutdown
R6-2611#show gatekeeper endpoints
GATEKEEPER ENDPOINT REGISTRATION
CallSignalAddr Port RASSignalAddr Port Zone Name Type F
172.31.1.2 1720 172.31.1.2 53198 R6-2611 VOIP-GW
H323-ID: R2-2811
172.31.1.3 1720 172.31.1.3 61240 R6-2611 VOIP-GW
H323-ID: R3-3825
Total number of active registrations = 2
R6-2611#show gatekeeper gw-type-prefix
GATEWAY TYPE PREFIX TABLE
Prefix: 1#*
Zone R6-2611 master gateway list:
172.31.1.3:1720 R3-3825
Zone R6-2611 prefix 405* priority gateway list(s):
Priority 10:
Zone R6-2611 prefix 200* priority gateway list(s):
Priority 5:
R6-2611#debug h225 asn1
H.225 ASN1 Messages debugging is on
R6-2611#terminal monitor
R6-2611#
*Mar 1 00:09:40.159: RAS INCOMING ENCODE BUFFER::= 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
*Mar 1 00:09:40.167:
*Mar 1 00:09:40.171: RAS INCOMING PDU ::=
value RasMessage ::= admissionRequest :
requestSeqNum 7445
callType pointToPoint : NULL
callModel direct : NULL
endpointIdentifier {"82694DAC00000002"}
destinationInfo
e164 : "2002000"
srcInfo
e164 : "4055702",
h323-ID : {"R3-3825"}
bandWidth 160
callReferenceValue 42
nonStandardData
nonStandardIdentifier h221NonStandard :
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '80000010A901810E184953444E20302F312F303A...'H
conferenceID 'BAE6AD7C640411DF80340026CBEA9800'H
activeMC FALSE
answerCall FALSE
canMapAlias TRUE
callIdentifier
guid 'BAE749A4640411DF80F5B26442D10AB4'H
willSupplyUUIEs FALSE
*Mar 1 00:09:40.191: H225 NONSTD INCOMING ENCODE BUFFER::= 80000010A901810E184953444E20302F312F303A313580AC00A949414D2C0D0A50524E2C6973646E2A2C2C515349472A2C0D0A5553492C726174652C632C732C632C310D0A5553492C6C6179312C616C61770D0A544D522C30300D0A43504E2C30302C2C752C323030323030300D0A43474E2C30302C2C752C792C322C343035353730320D0A4350432C30390D0A4643492C2C2C2C2C2C2C792C0D0A4743492C62616536616437633634303431316466383033343030323663626561393830300D0A0D0A0100
*Mar 1 00:09:40.199:
*Mar 1 00:09:40.199: H225 NONSTD INCOMING PDU ::=
value ARQnonStandardInfo ::=
sourceAlias
sourceExtAlias
callingOctet3a 129
interfaceSpecificBillingId "ISDN 0/1/0:15"
*Mar 1 00:09:40.203: RAS OUTGOING PDU ::=
value RasMessage ::= admissionReject :
requestSeqNum 7445
rejectReason calledPartyNotRegistered : NULL
*Mar 1 00:09:40.207: RAS OUTGOING ENCODE BUFFER::= 2C1D1400
05-22-2010 07:35 PM
This one is not coming with techprefix
destinationInfo
e164 : "2002000"
make sure the voip dial-peer that is pointing to GK has "tech-prefix 1# command configured
thanks
- abu
05-23-2010 10:06 PM
Prefix: 1#*
Priority 10:
Priority 5:
check out the prefix taken is 200* not the 202* like you wanted to configure it.
hth
