Remote VPN through public internet with access to private dmz
May 17th, 2010
Currently have a remote vpn setup which gives users access to the internal network. When I try to configure the same tunnels such that they can have access to the private dmz off the same ASA it doesn't work. Is it possible to do this?
Jon Marshall Mon, 05/17/2010 - 09:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Yes it is possible. Have you set up the same NAT exemption for the DMZ as you have for the inside (assuming you are using a nat exemption).
Jon
eocran Mon, 05/17/2010 - 10:15
Thanks for your response. I tried that and I'm using ios ver 8.04.
Ekow
