ACS runtime service will not start
jessica maitzen
Needed to sync up the ACS with the NTP server, which required a reload of the ACS.  Since the reload, the runtime application will not start. Log shows:
[UTC May 17 15:49:24] error    : 'runtime' process is not running
[UTC May 17 15:49:24] info     : 'runtime' trying to restart
[UTC May 17 15:49:24] info     : 'runtime' start: /opt/CSCOacs/bin/exec_wrapper.sh
[UTC May 17 15:50:24] error    : 'runtime' service timed out and will not be checked anymore
Unable to find any info on cisco.com knowldedge base.  Have reloaded three times with same result.  Any ideas?
Jatin Katyal
Jessica,
There are numerous issue with services on ACS code 5.0, please upgrade it to ACS 5.1
Go to Cisco.com > support > download software > Security > Cisco Secure Access Control System 5.0 > Secure Access Control System Software >
5.0.0.21
Upgrading an ACS server from 5.0 to 5.1 (Installation guide)
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/installation/guide/csacs_upg.html#wp1167547
Regds,
JK
Do rate helpul posts-
~Jatin
