Port Channel - Not Connect Problem
chrisalvarado
I'm trying to setup a port channel from a 2960G to a 3750G and I'm getting (Not connect) on the 3750 when I do a sho int Po1 command.  It shows connected on the 2960.  When I do a sho eth sum on each device things look good both ends show that they are bundled.  One difference I see when comparing the sho int po1 on the devices is that the 3750 shows a "Media-type configured as a connector"  see sho int command below.  Could this be the cause of the no connection on the port channel?  I know the cable is good because the uplink works fine when its not port channelled. Its only when I port channel the interface that connection is lost.  Both ends are running in access mode servicing one vlan.  Any ideas?  I've done many port channels and never come accros this one.  Thanks!
Port-channel1 is down, line protocol is down (notconnect)
  Hardware is EtherChannel, address is 000e.d753.f983 (bia 000e.d753.f983)
  Description: etherchannel to CORP-SW3-2960G
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Full-duplex, 1000Mb/s, link type is auto, media type is unknown
  Media-type configured as  connector
  input flow-control is off, output flow-control is unsupported
  Last input 00:44:06, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
22 Replies 22
spremkumar
Level 9
Level 9
Hi Chris
Can you revert back if you have any media-type command under there interface on any of the switches?
Also can you try using media-type sfp or rj45 based on the port/link you use to interconnect the switches.
regds
When I try the media-type command on the interconnect interface I get unsupported command.
I cant seem to find a way to negate the "Media-type configured as  connector"  When I do a sho int for any interface on the 3750  it shows them as configured as a connector .
How many Etherchannels do you currently have configured on the 2960?
Also could you post the configs?
Mike
Also what is the IOS on each?
Mike
3750G IOS-  (C3750-IPSERVICESK9-M), Version 12.2(25)SEE4
2960G IOS- (C2960-LANBASEK9-M), Version 12.2(44)SE6
Only one etherchannel on the 2960, which is trying to connect to 3750.  It shows connected on the 2960, but not connect on the 3750.  Status of (P) on both ends with the sho eth sum
Here's the 3750G config:
sho ru
Building configuration..
Current configuration : 22234 bytes
! Last configuration change at 12:16:41 PST Mon May 17 2010
! NVRAM config last updated at 11:42:30 PST Thu May 13 2010
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service sequence-numbers
hostname core-48
enable secret 5 $1$wYaK$NyCPlhuUZJrEjpiLXOU6U/
username admin privilege 15 secret 5 $1$BhxN$Z4kpzXzAx8HKDcvNlIaM90
no aaa new-model
clock timezone PST -8
switch 1 provision ws-c3750g-24t
switch 2 provision ws-c3750g-24t
switch 3 provision ws-c3750g-24t
--More--                           switch 4 provision ws-c3750g-24t
switch 5 provision ws-c3750g-48ts
ip subnet-zero
ip routing
ip cef load-sharing algorithm universal E6984C2C
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2  1
mls qos srr-queue input cos-map queue 1 threshold 3  0
mls qos srr-queue input cos-map queue 2 threshold 1  2
mls qos srr-queue input cos-map queue 2 threshold 2  4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3  3 5
mls qos srr-queue input dscp-map queue 1 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3  0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3  32
mls qos srr-queue input dscp-map queue 2 threshold 1  16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2  33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2  49 50 51 52 53 54 55 56
--More--                           mls qos srr-queue input dscp-map queue 2 threshold 2  57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3  40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3  5
mls qos srr-queue output cos-map queue 2 threshold 3  3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3  2 4
mls qos srr-queue output cos-map queue 4 threshold 2  1
mls qos srr-queue output cos-map queue 4 threshold 3  0
mls qos srr-queue output dscp-map queue 1 threshold 3  40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3  48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3  56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3  16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3  32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1  8
mls qos srr-queue output dscp-map queue 4 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3  0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
--More--                           mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
port-channel load-balance src-dst-ip
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
description etherchannel to CORP-SW3-2960G
switchport access vlan 4
switchport mode access
interface GigabitEthernet1/0/1
--description 10.1 Riverbed
speed 1000
duplex full
interface GigabitEthernet1/0/2
description .1
interface GigabitEthernet1/0/3
channel-group 1 mode desirable
interface GigabitEthernet1/0/4
description .5
switchport access vlan 5
interface GigabitEthernet1/0/5
description .5
--More--                           interface GigabitEthernet1/0/6
description .5
interface GigabitEthernet1/0/7
description .5
spanning-tree portfast
interface GigabitEthernet1/0/8
description .5
interface GigabitEthernet1/0/9
switchport access vlan 2
interface GigabitEthernet1/0/10
--More--                           !
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
--More--                            switchport mode access
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
--More--                            switchport access vlan 2
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
description LINK TO CORP-SW3-2960G
--More--                            switchport trunk native vlan 4
switchport mode trunk
shutdown
spanning-tree link-type point-to-point
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
speed 1000
duplex full
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
description BCWCK27
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface Vlan1
ip address 172.17.10.1 255.255.255.0
interface Vlan2
ip address 172.17.2.1 255.255.255.0
interface Vlan3
ip address 172.17.3.1 255.255.255.0
ip helper-address 172.17.2.6
interface Vlan4
ip address 172.17.4.1 255.255.255.0
interface Vlan5
ip address 172.17.5.1 255.255.255.0
interface Vlan7
ip address 172.17.8.1 255.255.255.0 secondary
ip address 172.17.7.1 255.255.255.0
interface Vlan8
--More--                            no ip address
interface Vlan10
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 172.17.10.4
ip http server
ip http authentication local
ip http secure-server
snmp-server community brwncald RW
snmp-server location Walnut Creek
control-plane
line con 0
line vty 0 4
password xxxxxx
login
--More--                            length 0
line vty 5 15
password xxxxxx
login
monitor session 1 source interface Gi1/0/1
monitor session 2 source interface Gi5/0/34
monitor session 2 destination interface Gi5/0/35
ntp clock-period 36029514
ntp server 172.17.2.63 key 0 prefer
end
HERE's the 2960G config
sho ru
Building configuration...
Current configuration : 6640 bytes
version 12.2
no service pad
hostname CORP-SW3-2960G
boot-start-marker
boot-end-marker
enable secret 5 $1$BKsn$B0K33PZ2xP1Q4BCwQljCd/
no aaa new-model
system mtu routing 1500
ip subnet-zero
crypto pki trustpoint TP-self-signed-1443897600
--More--                            enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1443897600
revocation-check none
rsakeypair TP-self-signed-1443897600
crypto pki certificate chain TP-self-signed-1443897600
certificate self-signed 01
  30820247 308201B0 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31343433 38393736 3030301E 170D3933 30333031 30303032
  31375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 34343338
  39373630 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CF3D 68DE3B2F 79E74662 D1684547 07336824 47861B32 83DCE113 049FD21C
  490B66AA 4935B1A6 AA9AABD6 DFFCF894 995A6CDE 22DC9DD7 9F8085CD 8513EC73
  E9AAF7A7 4D33F8A2 37EBB27F 67C68326 7EC5C0BD 8C474984 BA3B0344 71245842
  44FAF6E0 5D3A59C5 773C7D40 4C7E896E 397C75D5 E8E804D9 D672CF18 5DE30F3D
  1F4B0203 010001A3 6F306D30 0F060355 1D130101 FF040530 030101FF 301A0603
  551D1104 13301182 0F434F52 502D5357 332D3239 3630472E 301F0603 551D2304
  18301680 1437C99C 442FCD1F 292C3506 4C346F64 968DCB5D 82301D06 03551D0E
  04160414 37C99C44 2FCD1F29 2C35064C 346F6496 8DCB5D82 300D0609 2A864886
  F70D0101 04050003 8181004F ACE7B9B5 CEFA3E65 DA2A8B36 FD858508 67C7D64F
--More--                             3A972070 6C96A256 BD2C4DA7 4F79C536 9A54EEEF 09898B00 264DF878 64085D83
  69BFE32F ABF572ED 309CCD0D 02890F12 0FC7EDE0 F02E37A3 412A1201 E821DC6A
  7930AB85 E60EC46F EAB6C815 62C7B671 F7A51F9C 46D07E67 A0BBB29C 22E2E012
  BD5BE82C F72DD9F4 FC21E4
  quit
interface GigabitEthernet0/1
description UPLINK TO WCK CORE
--More--                            switchport access vlan 4
shutdown
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
--More--                           !
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
--More--                           interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
--More--                           !
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
--More--                           interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan4
ip address 172.17.4.14 255.255.255.0
no ip route-cache
ip default-gateway 172.17.4.1
ip http server
--More--                           ip http secure-server
snmp-server community brwncald RO
control-plane
line con 0
line vty 0 4
password xxxxxx
login
line vty 5 15
password xxxxxx
login
end
Also- the sho eth sum -
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)         PAgP      Gi1/0/3(P)
Also can you post the IOS versions for both. The 2960 needs to be 12.2(25)FX or later to support etherchannels.
Mike
You could try this config.....please verify the ports as the ones you want to use.
switchport
switchport nonegotiate
no shut
description Ether-Channel to Core
channel-group 1 mode on
no shut
no shut
description 4th Floor EtherChannel
switchport
no shut
switchport
no shut
interface GigabitEthernet2/3/37
switchport
no shut
Mike
Sorry the previous post was for trunked ports, while you can do it that way here is the way you had it so you can try this and see how it works for you.
switchport
no shut
switchport
no shut
switchport
no shut
switchport
no shut
switchport
no shut
switchport
no shut
Mike
Thanks, I tried them both....still showing down down, not connect on the port channel.  Also tried removing the port channel completely and re-creating it..no luck.
Hey,
Can you provide the show int po1 command ouput from the C2960 as well.
Rajeev Sharma.
Try to hardcode the speed/duplex setting at both the end make sure that there is no span port
I hard coded the duplex and speed and still showing (not connect) on the port channel interface on the 3750G
Here is the out for sho int po1 on the downstream 2960G:
sho int po1
Port-channel1 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 0021.5610.2102 (bia 0021.5610.2102)
  Keepalive set (10 sec)
  Members in this channel: Gi0/2
  Last input never, output 00:00:00, output hang never
     45904 packets input, 4925709 bytes, 0 no buffer
     Received 14391 broadcasts (14368 multicasts)
     0 watchdog, 14368 multicast, 0 pause input
--More--                                203253 packets output, 15082759 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
CORP-SW3-2960G#
