Cisco switch compatibility
Answered Question
May 17th, 2010
Hi all,
We plan to replace an unmanaged DLINK switch by a Cisco second hand unit (we don't have budget right now). We have one 3560 and two 2960 units. I just wanted to know if we can add to our network one 2950 unit easily.
Correct Answer by Ganesh Hariharan about 6 years 10 months ago
Hi all,
As per the good explanation from Nagendra,Unmanaged switches can be replaced with managed one that is  normal L2 switch 2950 in your case without any problem.
Check out the below link for insatllation and configuration of 2950 switches :-
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_9_ea1/configuration/guide/swvlan.html
Hope to help !!
Ganesh.H
Correct Answer by Nagendra Kumar ... about 6 years 10 months ago
My understanding about unmanaged switch is that htye will be used only for connectivity purpose and no other features can be enabled. From that point, you can very well replace DLINK with 2960. Apart from basic connectivity, you also have otehr features available.
Nagendra
Overall Rating: 5 (2 ratings)
Correct Answer
Nagendra Kumar ... Mon, 05/17/2010 - 10:18
  • Cisco Employee,
Nagendra
Correct Answer
Ganesh Hariharan Mon, 05/17/2010 - 22:56
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi all,
Hope to help !!
Ganesh.H
