How to connect a CISCO 2621 Router to the INTERNET ?
Answered Question
May 17th, 2010
I would like to connect my CISCO 2621 to my CISCO WRT610N ROUTER that is connected to my Internet Service Provider.
I have internet on my CISCO WRT610N , but I would like to pass it true my CISCO 2621 , I have been reading the 2 BIG books from the CCNA , but the only thing I can do is pinging the CISCO WRT610N , when I try to ping or go to a external internet page (ex www.google.com) , it does not work.
Where can I find some examples on NAT and RIP or other things that can maybe help me.
I have just order a Cisco WIC-1DSU-T1 1-Port T1/Fractional T1 DSU/CSU WAN on eBAY , maybe what I try to do on F0/0 or F0/1 does not work ?
When I understand and are able to make it work , I would like to remove the CISCO WRT610 ROUTER and use the CISCO 2621 instead in my small lab.
Thank you for your help.
Best Regards,
Didier.
Correct Answer by Ganesh Hariharan about 7 years 2 months ago
Thank you for your prompt reply
It seams I have no access to the above links , I will contact CISCO today , to update my profile / account.
But so far I can see this will be the place where I will find what I need.
Thank You again,
Best Regards,
Didier
Hi Didier,
Check out the below link for NAT and RIP/EIGRP configuration on Cisco routers
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
http://www.tomax7.com/mcse/cisco_routerconfig.htm
Hope to Help !!
Ganesh.H
Overall Rating: 5 (2 ratings)
Leo Laohoo Mon, 05/17/2010 - 17:07
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Sample Configuration Using the ip nat outside source list Command
http://www.cisco.com/en/US/customer/tech/tk648/tk361/technologies_configuration_example09186a0080093f8e.shtml
Sample Configuration Using the ip nat outside source static Command
http://www.cisco.com/en/US/customer/tech/tk648/tk361/technologies_configuration_example09186a0080093f2f.shtml
Configuring Routing Information Protocol
http://www.cisco.com/en/US/customer/docs/ios/12_2/ip/configuration/guide/1cfrip.html
Don't forget to rate useful posts.  Thanks.
Didier1966 Mon, 05/17/2010 - 22:07
Thank You again,
Best Regards,
Didier
Correct Answer
Ganesh Hariharan Mon, 05/17/2010 - 22:10
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Thank You again,
Best Regards,
Didier
Hi Didier,
Hope to Help !!
Ganesh.H
Didier1966 Tue, 05/18/2010 - 11:28
Hi Ganesh,
Thank you for this links , this one I can open
The second one is really interesting , I will try it this evening when I am back home.
Thank's again and Best Regards,
Didier
