CUCM 7.1(3b)SU2 CLIP HiPath E1 MGCP QSIG
May 17th, 2010
we are trying to connect a CUCM (Ver. 7.1(3b)SU2) with MGCP over a E1 trunk to a Hipath 4000. We use for the QSIG ECMA with Globale Values.
Features like callback and call forward by reroute works fine, but we don't get the caller name on the Cisco Phone (6961 and 7975) from the HiPath Phones.
I read also this bug CSCtc68166 at this post https://supportforums.cisco.com/message/3049636.
Have I maybe this issue with the 7.1.(3b)SU2 version, or should I downgrad to 7.1(3a)SU1 aka (7.1.3.21900-4)?
We still let configured at the HiPath the ?Segment? 8?
Thanks for your suggestions in advance.
Best Regards,
Paul
paulheilmeier Tue, 05/18/2010 - 13:14
Maybe some additional information.
In the debug log on the voicegateway (debug isdn q931) I didn't see any caller name from the Cisco Phone (also not in facility ie), only the name of the called phone which is connected to the hipath.
I try tomorrow to post the debuglog.
paulheilmeier Tue, 11/16/2010 - 04:44
We solved this issue, by not using the standard local route group inside the router pattern, which is pointing to the HiPath.
