Dial back up on an 891
May 17th, 2010
Hi There,
I am currently reviewing the 891 Router as a replacement for my 1811's in the field, but I am running into a problem with the dialer interface not working properly.
I've used what is essentially the same config from my 1811, and it works if I copy the config over line-by-line (the dialer binds, and I get a solid connection to my VPN), until I restart the router. At this point i get the errors
%Remove Dialer Profile Configuration first
%Warning:Use P2P interface for routemapset
                           interface clause
C
% Incomplete command
C
I seem to be at a loss for what this means, can someone help me out?
Ganesh Hariharan Mon, 05/17/2010 - 23:03
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi There,
                           interface clause
C
C
Check out the below link for configuration of dailer list in cisco 860,880 and 890 series routers
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/software/configuration/guide/routconf.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Related Content
