CUCIMOC Compatible Headset?
Answered Question
May 17th, 2010
We have just completed a large UC deployment where CUCIMOC is the primary telephony device for about 3/4 of the users base. However, none of the wireless Plantronics headsets we are using work with CUCIMOC the way they should (bluetooth and USB).
The main issue is that a user can't answer a call by pressing the button on the earpiece, you cannot get dialtone by pressing the button either.
The headsets work FINE with IP Communicator and MOC.. just not COCIMOC.
Needless to say the customer is a bit miffed.
So, does anyone have any suggestions AND field experience with a headset that works with CUCIMOC? (Or knows how to get these working?)
- Sam
Correct Answer by Jaime Valencia about 6 years 8 months ago
From what I know it should be until 8.5 release, not sure about the timeframe but if it's the same as other products it should be Q4CY10
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
The RNs contains a list of tested devices:
Client Computer Requirements
http://www.cisco.com/en/US/docs/voice_ip_comm/cucimoc/7_1/english/release/cucimocReleaseNote.html#wp51908
Tested Audio Devices
The audio devices tested with Cisco UC Integration for Microsoft Office Communicator are as follows:
ClearOne CHAT 50 USB
Plantronics Voyager 510 Bluetooth
Jabra GN8110 USB
Jabra GN8120 USB
Jabra GN9120
Jabra Advantage Plus
Plantronics CS50
Plantronics CS60
Plantronics DA60 USB
Plantronics DSP-400
Plantronics DA55 USB
Clarisys i750
Headset user controls are not supported at the time, this is roadmapped.
java
Overall Rating: 5 (3 ratings)
Correct Answer
Jaime Valencia Mon, 05/17/2010 - 14:45
Jabra GN8110 USB
Jabra GN8120 USB
Jabra GN9120
Plantronics CS50
Plantronics CS60
Plantronics DSP-400
Clarisys i750
java
Sam Alexander Tue, 05/18/2010 - 05:59
Is there any timeline on the support?  I know it's not in thelatest beta, so if not now, when?
