Help whit WLC 4402 ?
May 17th, 2010
I have problems with the wireless network, I have users connected and suddenly start to feel the network latency and reduced the speed to be working at 54 mbps to 1 mbps down and then disconnect, it proceeded to change the version of IOS the WLC from version 5 to version 6 and proceeded to make a change in the Session Timeout, and began its maximum value soportabley are no longer disconnects users but I still have speed and low latency in the network, under the tx team and modify the velocities of 1 and 2 were supported Megas and 5.5 were below an continuous Osilo Mandatory but the customers who are working at 54 Mbps and then switch to 6 or 3 Mbps and then to 24 or 32 Mbps.
Any Idea ?
WLC  4402 ver 6.0.196.0
AP: AIR-AP1242AG-A-K9
Software Version 6.0.196.0
Boot Version: 12.3.7.1
IOS Version: 12.4(21a)JHA
Mini IOS Version: 3.0.51.0
Loggs:
*May 17 17:01:42.191: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M3 retransmissions exceeded for client 00:24:9f:ef:5c:be
*May 17 15:46:55.745: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:14:a5:f5:77:6b
*May 17 15:06:43.083: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M5 retransmissions exceeded for client 00:14:a5:f5:77:6b
*May 17 14:53:35.730: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:21:5d:18:d0:64 due to switch of WLANs from 3(APTI) to 1(APU)
*May 17 14:42:11.868: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M3 retransmissions exceeded for client 00:24:9f:ef:5c:be
*May 17 14:20:45.753: %APF-1-CHANGE_ORPHAN_PKT_IP: apf_foreignap.c:1288 Changing orphan packet IP address for station00:1f:f3:98:08:3b from 1.2.3.116 --->1.2.3.29
*May 17 14:20:45.752: %APF-1-CHANGE_ORPHAN_PKT_IP: apf_foreignap.c:1288 Changing orphan packet IP address for station00:1f:f3:98:08:3b from 1.2.3.29 --->1.2.3.116
*May 17 14:20:45.752: %APF-1-CHANGE_ORPHAN_PKT_IP: apf_foreignap.c:1288 Changing orphan packet IP address for station00:1f:f3:98:08:3b from 1.2.3.116 --->1.2.3.29
*May 17 14:20:45.713: %APF-1-CHANGE_ORPHAN_PKT_IP: apf_foreignap.c:1288 Changing orphan packet IP address for station00:1f:f3:98:08:3b from 1.2.3.116 --->1.2.3.29
*May 17 14:06:24.847: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:24:9f:ef:5c:be
*May 17 14:02:18.044: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:24:9f:ef:5c:be
*May 17 13:58:35.441: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:24:9f:ef:5c:be
*May 17 13:58:16.041: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:24:9f:ef:5c:be
*May 17 13:57:52.241: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M3 retransmissions exceeded for client 00:21:5d:18:d0:64
*May 17 11:57:06.666: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:21:5d:18:d0:64 due to switch of WLANs from 1(APU) to 3(APTI)
*May 17 11:43:32.100: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:13:ce:dd:6a:df due to switch of WLANs from 3(APTI) to 1(APU)
*May 17 11:24:45.076: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:354 Invalid replay counter from client 00:13:ce:dd:6a:df - got 00 00 00 00 00 00 00 00, expected 00 00 00 00 00 00 00 01
*May 17 11:24:43.748: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:13:ce:dd:6a:df
*May 17 10:54:31.600: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:354 Invalid replay counter from client 00:13:ce:dd:6a:df - got 00 00 00 00 00 00 00 00, expected 00 00 00 00 00 00 00 01
*May 17 10:54:29.131: %DOT1X-3-INVALID_WPA_KEY_MSG_STATE: 1x_eapkey.c:705 Received invalid EAPOL-key M2 msg in START state - invalid secure bit; len 22, key type 1, client 00:13:ce:dd:6a:df
*May 17 10:54:26.927: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:13:ce:dd:6a:df
*May 17 10:50:43.155: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:21:6b:47:7d:40 due to switch of WLANs from 3(APTI) to 1(APU)
*May 17 10:13:42.244: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:354 Invalid replay counter from client 00:13:ce:dd:6a:df - got 00 00 00 00 00 00 00 00, expected 00 00 00 00 00 00 00 01
*May 17 10:13:42.242: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:354 Invalid replay counter from client 00:13:ce:dd:6a:df - got 00 00 00 00 00 00 00 02, expected 00 00 00 00 00 00 00 01
*May 17 10:13:42.234: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:354 Invalid replay counter from client 00:13:ce:dd:6a:df - got 00 00 00 00 00 00 00 00, expected 00 00 00 00 00 00 00 01
*May 17 10:13:40.303: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:13:ce:dd:6a:df
*May 17 10:13:36.903: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:13:ce:dd:6a:df
*May 17 09:43:22.912: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:13:ce:dd:6a:df due to switch of WLANs from 1(APU) to 3(APTI)
*May 17 09:25:08.731: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:21:6b:3e:c9:c6 due to switch of WLANs from 3(APTI) to 1(APU)
*May 17 08:22:46.865: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:21:6b:3e:c9:c6 due to switch of WLANs from 1(APU) to 3(APTI)
*May 17 07:48:16.616: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:292 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*May 17 07:48:14.482: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:292 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*May 17 07:48:12.979: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:292 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*May 17 07:48:12.826: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:292 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*May 17 07:48:12.660: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:292 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*May 17 04:47:04.099: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:5232 Did not receive heartbeat reply; AP: 00:25:84:94:3c:90
*May 17 04:46:57.899: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:5232 Did not receive heartbeat reply; AP: 00:26:0b:15:ac:f0
*May 17 04:46:48.299: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:5232 Did not receive heartbeat reply; AP: 00:25:84:95:14:50
*May 17 04:46:47.699: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:5232 Did not receive heartbeat reply; AP: 00:26:0b:15:ae:60
*May 17 04:46:47.499: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:5232 Did not receive heartbeat reply; AP: 00:26:0b:15:b0:30
*May 15 11:38:57.564: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:516 Client 00:14:a5:f5:77:6b may be using an incorrect PSK
*May 15 11:38:57.562: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:14:a5:f5:77:6b
*May 15 11:38:54.162: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:14:a5:f5:77:6b
*May 15 11:38:50.762: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:14:a5:f5:77:6b
*May 15 11:38:47.362: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:14:a5:f5:77:6b
*May 14 18:50:51.131: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M5 retransmissions exceeded for client 00:1d:4f:d6:85:c3
*May 14 18:20:19.796: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:354 Invalid replay counter from client 00:14:a5:f5:77:6b - got 00 00 00 00 00 00 00 00, expected 00 00 00 00 00 00 00 01
*May 14 17:49:38.092: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M5 retransmissions exceeded for client 00:13:ce:dc:e0:64
*May 14 17:38:36.270: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:21:6b:47:7d:40 due to switch of WLANs from 1(APU) to 3(APTI)
*May 14 16:48:35.046: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M5 retransmissions exceeded for client 00:1d:4f:d6:85:c3
*May 14 15:56:39.616: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M5 retransmissions exceeded for client 00:14:a5:f5:77:6b
*May 14 15:44:59.007: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M5 retransmissions exceeded for client 00:1d:4f:d6:85:c3
*May 14 15:25:16.265: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:21:5d:18:d0:64 due to switch of WLANs from 1(APU) to 3(APTI)
*May 14 14:44:02.971: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M5 retransmissions exceeded for client 00:1d:4f:d6:85:c3
*May 14 14:20:20.760: %DOT1X-3-INVALID_WPA_KEY_MSG_STATE: 1x_eapkey.c:705 Received invalid EAPOL-key M2 msg in START state - invalid secure bit; len 22, key type 1, client 00:13:ce:dc:e0:64
*May 14 14:14:54.953: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M5 retransmissions exceeded for client 00:21:00:b7:3b:a2
*May 14 14:14:46.485: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:13:ce:dc:e0:64 due to switch of WLANs from 1(APU) to 3(APTI)
*May 14 14:13:38.133: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:13:ce:dc:e0:64 due to switch of WLANs from 3(APTI) to 1(APU)
*May 14 14:13:02.014: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:13:ce:dc:e0:64 due to switch of WLANs from 1(APU) to 3(APTI)
*May 14 14:12:50.911: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:13:ce:dc:e0:64 due to switch of WLANs from 3(APTI) to 1(APU)
*May 14 12:49:20.499: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M5 retransmissions exceeded for client 00:14:a5:f5:77:6b
*May 14 12:41:43.257: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:354 Invalid replay counter from client 00:21:00:b7:3b:a2 - got 00 00 00 00 00 00 00 00, expected 00 00 00 00 00 00 00 01
*May 14 12:15:04.249: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:21:6b:3e:c9:c6 due to switch of WLANs from 3(APTI) to 1(APU)
*May 14 12:10:14.875: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M5 retransmissions exceeded for client 00:13:ce:dc:e0:64
*May 14 11:46:41.092: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:13:ce:dc:e0:64 due to switch of WLANs from 3(APTI) to 1(APU)
*May 14 10:56:43.846: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:354 Invalid replay counter from client 00:12:f0:5b:a3:f4 - got 00 00 00 00 00 00 00 01, expected 00 00 00 00 00 00 00 02
*May 14 10:56:43.844: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:354 Invalid replay counter from client 00:12:f0:5b:a3:f4 - got 00 00 00 00 00 00 00 00, expected 00 00 00 00 00 00 00 02
*May 14 10:31:47.061: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:13:ce:dc:e0:64 due to switch of WLANs from 1(APU) to 3(APTI)
*May 14 10:31:06.469: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:13:ce:dc:e0:64 due to switch of WLANs from 3(APTI) to 1(APU)
*May 14 10:24:12.409: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:13:ce:dc:e0:64
*May 14 10:24:09.521: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2234 Could not process the RSN and WARP IEs. station not using WPA or WPA2 on WLAN requiring WPA and/or WPA2.MobileStation: 00:13:ce:dc:e0:64, SSID:APTI,AP: 00:1e:bd:66:08:70.
*May 14 10:20:22.026: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:19:d2:2e:c4:ac due to switch of WLANs from 3(APTI) to 1(APU)
*May 14 10:20:21.806: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:19:d2:2e:c4:ac
*May 14 10:20:17.712: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:19:d2:2e:c4:ac due to switch of WLANs from 1(APU) to 3(APTI)
*May 14 10:20:14.974: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:19:d2:2e:c4:ac due to switch of WLANs from 3(APTI) to 1(APU)
*May 14 10:19:20.607: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:19:d2:2e:c4:ac
*May 14 10:19:17.606: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:19:d2:2e:c4:ac
*May 14 10:19:14.606: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:19:d2:2e:c4:ac
*May 14 10:05:58.256: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:21:6b:3e:c9:c6 due to switch of WLANs from 1(APU) to 3(APTI)
*May 14 10:04:40.668: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:21:6b:3e:c9:c6 due to switch of WLANs from 3(APTI) to 1(APU)
*May 14 10:04:38.444: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:21:6b:3e:c9:c6 due to switch of WLANs from 1(APU) to 3(APTI)
*May 14 09:52:27.141: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:21:6b:3e:c9:c6 due to switch of WLANs from 1(APU) to 3(APTI)
*May 14 09:32:08.207: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:21:6b:3e:c9:c6 due to switch of WLANs from 3(APTI) to 1(APU)
*May 14 09:25:34.573: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:407 Max EAPOL-key M1 retransmissions exceeded for client 00:12:f0:5b:a3:f4
*May 14 09:19:51.765: %APF-1-DISCONECT_MOBILE_DUE_TO_WLAN_SW: apf_policy.c:540 Disconnecting mobile 00:21:6b:3e:c9:c6 due to switch of WLANs from 1(APU) to 3(APTI)
*May 14 08:19:22.399: %WEB-3-INVALID_TFTP_DNLDCODE: file_download.c:893 TFTP download failed with unknown failure code.
Leo Laohoo Mon, 05/17/2010 - 16:58
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
How many clients are connected to a particular AP.  From what I gather of the description of your problem it sounds that clients are overwhelming ONE AP with traffic.
xeum96700 Mon, 05/17/2010 - 19:02
About 15 clients per AP, should enable  Aggressive Load Balancing
Leo Laohoo Mon, 05/17/2010 - 19:13
  • Hall of Fame,
    2017 LAN, Wireless
How far are they from the AP?  Disable the lower MCS rates and make the higher rates "Mandatory".
xeum96700 Mon, 05/17/2010 - 19:24
I have 5 APs at a distance of approximately 10 meters between them at a height of 2.40 meters, to meet the demand of approximately 70 repeat users, and we already disable the lower rates, but we have not as mandatory as all other rates
Related Content
