Difference B/W Layer 3 Switch & Multi Layer Switch?
Dear All,
           Is there any difference between Layer 3 switch and Multi Layer Switch?..My friend told that Layer 3 switch can perform Multi Layer Switch but Multi Layer switch cant perform Layer 3 Switch task..Is it Correct?
Please give any clear idea on this?
Thnks in advance
Senthil
Ganesh Hariharan
Dear All,
Thnks in advance
Senthil
Hi Senthil,
The generic widely used term multilayer switch means a switch that can do layer 2 and/or layer 3 switching on the same platform. This definition is used interchangeably with layer 3.However, multilayer switch is also used to describe switches which can make decisions on informnation in layer 4-7 as well.
Switches That forward  frames based on Layer 3 and 4 information contained in packets. This is known as multilayer switching (MLS).
A multilayer switch can have ports configured as layer 2 or layer 3. And is capable of routing packets between networks (VLANs).  A layer 3 switch is basically a router (albilty to have ery fast and with a bunch of ports).
layer 3 means its capable of routing between vlans and able to join eigrp, rip and things. you can make any of the ports on the switch a routed port. this means you can use a layer3 switch exclusively as a router if you wanted to.
Hope to help !!
Ganesh.H
Remember to rate the helpful post
Ganesh Hariharan
Dear All,
Thnks in advance
Senthil
Hi Senthil,
Hope to help !!
Ganesh.H
Dear Ganesh,
Thanks for your reply to this post..Can we perform Layer 4-7 information in  Layer 3 Switch?(Little bit doubt)
Tks&Rgds
Senthil
Dear Ganesh,
Tks&Rgds
Senthil
Hi Senthil,
As i Already told you Layer 3 switches is a high-performance device for network routing,The hardware inside a Layer 3 switch merges that of traditional switches and routers, replacing some of a router's software logic with hardware to offer better performance in some situations.
Some switches can use up to OSI layer 7 packet information; they are called layer 4-7 switches, content-switches, content services switches, web-switches or application-switches.
Hope to Help !!
Ganesh.H
I completly agree with what ganesh said. It actually depends on the switch you have and it varies b/w different models.
regards,
Varun
