fabien.damien Tue, 05/18/2010 - 22:26
HI Geoff,
i have used a MIB browser to browse the above file, however i'm not able to see possible OID values (which was possible for ICM)
for instance if i want to check vxml server service status which OID should i poll?
What sor of MIB browser? I use iReasoning and downloaded the following MIBs from the Cisco FTP server
CISCO-CVP-MIB.my
CISCO-TC.my
CISCO-SMI.my
and copied them into the iReasoning\mib directory. Then I loaded the CISCO-CVP.MIB and can see all the OIDs.
You can also download the OID file itself.
### THIS FILE WAS GENERATED BY MIB2SCHEMA
"org"  "1.3"
"dod"  "1.3.6"
"internet"  "1.3.6.1"
"directory"  "1.3.6.1.1"
"mgmt"  "1.3.6.1.2"
"experimental"  "1.3.6.1.3"
"private"  "1.3.6.1.4"
"enterprises"  "1.3.6.1.4.1"
"cisco"  "1.3.6.1.4.1.9"
"ciscoMgmt"  "1.3.6.1.4.1.9.9"
"ciscoCvpMIB"  "1.3.6.1.4.1.9.9.590"
"ciscoCvpMIBNotifs"  "1.3.6.1.4.1.9.9.590"
etc.
Go to ftp://ftp-sj.cisco.com/pub/mibs/ and have another look - check the README-MIB.txt file for info.
Geoff
fabien.damien Thu, 05/20/2010 - 01:16
Hi Geoff,
i'm also using Ireasoning mib Browser. Can you give an example in which you check if VXML service is down using OID?
i'm not able to find the service and its corresponding status.In CISCO-CONTACT-CENTER-APPS-MIB.my i was able to view tables where each field has its own OID shown clearly.(check screenshot for more details)
