RVL200 EOL - Replacement?
May 17th, 2010
Hello, I was looking at the RVL200 for my client who needs to have remote access to his office LAN. However, I see that the RVL200 is no longer sold from April 2010. As such, may I know if there is a newer VPN router to replace the RVL200 which is specifically for small business and allows for VPN.
Currently there is an ADSL modem + router which connects the client LAN to the Internet. So with the new VPN router, do I have to replace the modem + router or can I connect it after the modem+router device. The modem+router device is Thomson Speedtouch 585 which is given by the ISP.
Any help and advice would be most appreciated. Thanks.
