Give me your opinion
anas-hazeen
I have main router CISCO 3825 VO4 and main switch C3560 48P
and you will see here the running configuration in the router
Plz can you tell me your opinion in this scenario
and if you can give me any concepts or ideas to improve it
show run
Building configuration...
version 12.4
service config
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime
service password-encryption
service compress-config
hostname mainRouter
boot-start-marker
boot system flash c3825-advsecurityk9-mz.124-22.T.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging message-counter syslog
no logging buffered
enable secret 5 ##############
aaa new-model
aaa authentication login TEMP group tacacs+ local enable
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ local
aaa authorization commands 1 default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
aaa accounting exec default
action-type start-stop
group tacacs+
aaa accounting commands 1 default
group tacacs+
aaa accounting commands 15 default
group tacacs+
aaa accounting system default
group tacacs+
aaa session-id common
dot11 syslog
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip domain name mydomain.com
ip name-server (IP of Internet Server)
crypto pki trustpoint TP-self-signed-#########
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-#########
revocation-check none
rsakeypair TP-self-signed-#########
crypto pki certificate chain TP-self-signed-##########
certificate self-signed 01
  30820248 308201B1 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32343035 39353035 3533301E 170D3039 30323039 31303036
  34315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  ets….
archive
log config
  logging enable
  hidekeys
crypto isakmp policy 10
encr aes
authentication pre-share
crypto isakmp key ############# address (Location2) no-xauth
crypto ipsec transform-set AES ah-sha-hmac esp-aes 256
crypto ipsec profile Main-location-to-location2-GRE-IPSec
set transform-set AES
ip tcp synwait-time 10
ip telnet source-interface GigabitEthernet0/1.8
ip ssh source-interface Tunnel0
ip ssh logging events
ip ssh version 2
ip scp server enable
interface Loopback0
ip address 10.0.0.254 255.255.255.248
interface Tunnel0
description - GRE/IPSec Tunnel to location2
ip address 10.0.0.15 255.255.255.252
tunnel source (Main-location-IP)
tunnel destination (location2-IP)
interface GigabitEthernet0/0
description - fibre link to My ISP
no ip address
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip virtual-reassembly
duplex auto
speed auto
media-type rj45
no mop enabled
interface GigabitEthernet0/0.444
description - MPLS VLAN 444
encapsulation dot1Q 444
ip address (Real IP 1)
ip flow ingress
no cdp enable
interface GigabitEthernet0/0.461
description - VPN VLAN 461
encapsulation dot1Q 461
ip address (Real IP 2)
description - Main Router to main Switch
no ip address
duplex auto
speed auto
media-type rj45
encapsulation dot1Q 8
ip address (Real IP)
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address 10.0.0.12 255.255.255.252
interface Group-Async0
physical-layer async
no ip address
encapsulation slip
no group-range
router eigrp 1
redistribute ospf 1 metric 1 1 1 1 1 route-map OSPF2EIGRP
passive-interface GigabitEthernet0/0.444
passive-interface GigabitEthernet0/1.8
network 10.0.0.14 0.0.0.3
auto-summary
router ospf 1
router-id 10.0.0.254
log-adjacency-changes
redistribute eigrp 1 metric 10 subnets route-map EIGRP2OSPF
redistribute bgp 64917 metric 10 subnets route-map BGP2OSPF
network 10.0.0.12 0.0.0.0 area 1
router bgp 64917
no synchronization
bgp log-neighbor-changes
redistribute ospf 1 route-map OSPF2BGP
neighbor (Real IP) remote-as 65000
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 (IP of ISP)
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip tacacs source-interface Tunnel0
ip access-list standard Group1
permit (Some IPs)
deny   any
ip access-list standard Group2
permit (Some IPs)
deny   any
ip access-list standard Group3
permit (Some IPs)
deny   any log
ip access-list standard Group4
permit (Some IPs)
deny   any log
logging trap debugging
logging facility local4
logging source-interface Tunnel0
route-map BGP2OSPF permit 10
match ip address Group1
route-map OSPF2BGP permit 10
match ip address Group3
route-map OSPF2EIGRP permit 10
route-map EIGRP2OSPF permit 10
match ip address Group2
tacacs-server host (tacacs-Server-IP) key 7 ###############
control-plane
line con 0
login authentication TEMP
transport output telnet
line aux 0
line vty 0 4
access-class Group4 in
transport input telnet ssh
line vty 5 15
scheduler allocate 20000 1000
end
Leo Laohoo
Aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaand what are you trying to do/achieve?  You provided a config (thank you, by the way) but that's it?  As far as I can see it's "ok" if you don't want to run encryption across your WAN links.
Thank you for that
and about "encryption across your WAN links"
Yes,  I hope that
plz. give me your ideas for encryption across WAN
thanks
