05-18-2010 12:36 AM - edited 03-06-2019 11:08 AM
We have a few switches and routers and we use local logons with different privileges, is there a way I can centrally do this, I've never used Cisco works before, but it this a tool that can do that?
05-18-2010 12:52 AM
We haev a few switches and routers and we use local logons with different privileges, is there a way I can centrally do this, I've never used Cisco works before, but it this a tool that can do that?
I dont think cisco works used for authentication purpose in order to have authentication of devices you can have TACAS or RADIUS like ACS server insatlled in your network which can be used for AAA purpose fo your devices.
Hope to help !!
Ganesh.H
05-18-2010 01:25 AM
Thanks, what to common mode engineers use, we only have a windows IAS Radius server, also can these tools control privileges?
05-18-2010 01:28 AM
Configuring RADIUS and TACACS+ Servers
http://www.cisco.com/en/US/customer/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43radi.html
05-18-2010 01:32 AM
Can these control privileges aswell as authentication? Also
is TACACS= a piece of Cisco software we haev to buy?
05-18-2010 01:56 AM
Andy,
All depends on the server using the protocol like radius or tacas,If you are using Radius then devices need to communicate on radius protocol with servers for authentication and authorization.
Check out the radius attributes for authorzation purpose in servers with client
http://www.ciscosystems.com/en/US/docs/ios/11_3/security/configuration/guide/scratrib.html#wp307
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
05-18-2010 02:08 AM
I've never used TACACS, I guess this is quite costly (can't find pricing)?
Radius is free on Windows server, maybe this is my only option.
05-18-2010 02:13 AM
Check out the below link for IAS radius intergartion with cisco devices , along with comparism details for TACAS and RADIUS.
http://www.tech-recipes.com/rx/1478/how-to-setup-ias-to-use-radius-to-authenticate-cisco-device/
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a0080094e99.shtml
Hope to Help !!
Ganesh.H
