XMODEM FAIL with no notice in 3620 router
Cisco 3620 router 16M*4 DRAM,16MB+8MB Flash SIMM
PCMCIA Slot1: No Card Present
System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
C3600 processor with 65536 Kbytes of main memory
Main memory is configured to 32 bit mode with parity disabled
device does not contain a valid magic number
boot: cannot open "flash:"
boot: cannot determine first file name on device "flash:"
rommon 1 > xmodem -c c3620-ik9o3s6-mz.123-26.bin
Do not start the sending program yet...
dir: cannot open device "flash:"
WARNING: All existing data in flash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n  [n]:  y
Ready to receive file c3620-ik9o3s6-mz.123-26.bin ...
C
after transfer is complete,nothing shows up   so I restart the router
previous xmodem doesn't work out?
PCMCIA Slot0: No Card Present
rommon 1 > ?
alias               set and display aliases command
boot                boot up an external process
break               set/show/clear the breakpoint
confreg             configuration register utility
cont                continue executing a downloaded image
context             display the context of a loaded image
cookie              display contents of cookie PROM in hex
dev                 list the device table
dir                 list files in file system
dis                 disassemble instruction stream
dnld                serial download a program module
frame               print out a selected stack frame
help                monitor builtin command help
history             monitor command history
meminfo             main memory information
repeat              repeat a monitor command
reset               system reset
set                 display the monitor variables
stack               produce a stack trace
sync                write monitor environment to NVRAM
sysret              print out info from last system return
unalias             unset an alias
unset               unset a monitor variable
xmodem              x/ymodem image download
rommon 2 > xmodem -c c3620-ik9o3s7-mz.123-22.bin
Ready to receive file c3620-ik9o3s7-mz.123-22.bin ...
Erasing flash at 0x317c0000
program flash location 0x30310000
then stuck here ,I restart it
rommon 1 >
rommon 2 > dir flash:
         File size           Checksum   File name
  15120140 bytes (0xe6b70c)   0x7f2e    c3620-ik9o3s7-mz.123-22.bin (bad checksu
m: 0x5bd5)
rommon 3 >
c3620-ik9o3s6-mz.123-26.bin is 16.3MB and c3620-ik9o3s7-mz.123-22.bin is 14.4MB ,and I have one 8MB and one 16MB Flash SIMM installed.Will it work this way?or something else is wrong?
my last try with only one 16MB SIMM,still stuck after transferring
m: 0x5bd5)
Erasing flash at 0x30fc0000
program flash location 0x30660000
stuck
Problem solved I guess the flash partition info is somehow corrupted
solution
1.rommon   xmodem -r
2.IOS   format flash
3.IOS copy xmodem: flash:
If not necessary,don't jerk around with a actual router   simulators are pretty much enough for a lot of things
Leo Laohoo
ROMmon Recovery for the Cisco 3600/3700/3800 Series Routers
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a008009429f.shtml
Xmodem Procedure for Downloading a Cisco IOS Software Image onto a Cisco 3600 Router
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml#proc_3600
Can you try "xmodem -r" switch/option?  This will load the IOS on the DRAM so you can use the IOS to determine what is wrong with your PCMCIA flash cards.
7 Replies 7
Ganesh Hariharan
Check out the below link for help !!
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a0080094aef.shtml
Ganesh.H
If helpful do rate the post
Leo Laohoo
Xmodem always get stuck after transferring
rommon 2 > dev
Devices in device table:
        id  name
    flash:  flash
    slot0:  PCMCIA slot 0
    slot1:  PCMCIA slot 1
    eprom:  eprom
rommon 3 > dir flash:
m: 0x64a2)
I don't know why I always get bad checksum using xmodem
I don't have a PCMCIA card.The router has 4*16MB DRAM SIMMs and 1*16MB Flash SIMM.
Thanks.I am trying xmodem -r .
BTW Can I download a 16.3MB image to a router using 1*16MB Flash SIMM+1*8MB Flash SIMM
Leo Laohoo
Errrr ... That's what the PCMCIA Flash cards are for.  The only way to run the IOS is to load it into the DRAM.    XModem will get "stuck" because it's trying to write to a media that doesn't exist.
Bad checksum could mean the orginal file you have may and could be corrupt or incomplete.
It does have 2 Flash SIMMs,no PCMCIA tho        not a router without Flash  lol
I have used the images before and it's not likely to happen that both of the images are corrupted.I suspect it's something with Tera Term cuz I've set BAUD to 115200.But it worked fine yesterday.
I am positive that the Flash has an image yesterday.I just switched the SIMMs  among 3 3620 routers but it just doesn't work.
Nuts!  My brains is currently stuck sometime after the 3rd can of Red Bull.  I think I am confusing myself with the 3600 and the 3700.
Yes, the 3600 do have the DRAM and a Flash modules internally.
Again, try using the "-r" switch to determine why the internal flash modules aren't taking the IOS.  Maybe your IOS file could be corrupt or incomplete.
rommon 6 > xmodem -r c3620-ik9o3s7-mz.123-22.bin
Ready to receive file  ...
Download Complete!
program load complete, entry point: 0x80008000, size: 0xe6b5c8
Self decompressing the image : #################################################
########################################################## [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
                0X00098670 public buffer pools
                0X00211000 public particle pools
TOTAL:          0X002A9670
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 3Mb.
adjusted iome size up to minimum size of: 0X00400000
Using 6 percent iomem. [4Mb/64Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) 3600 Software (C3620-IK9O3S7-M), Version 12.3(22), RELEASE SOFTWARE (fc
2)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Wed 24-Jan-07 17:37 by ccai
Image text-base: 0x60008B00, data-base: 0x61950000
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco 3620 (R4700) processor (revision 0x81) with 61440K/4096K bytes of memory.
Processor board ID 26883880
R4700 CPU at 80MHz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
%Error: Invalid partition size parameters(s).
%Error: Requested partitions not valid.
Press RETURN to get started!
*Mar  1 00:00:03.299: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0
, changed state to up
*Mar  1 00:00:06.671: %LINK-4-NOMAC: A random default MAC address of 0000.0c86.3
880 has
  been chosen.  Ensure that this address is unique, or specify MAC
  addresses for commands (such as 'novell routing') that allow the
  use of this address as a default.
00:00:14: %SYS-5-CONFIG_I: Configured from memory by console
00:00:17: %SYS-5-RESTART: System restarted --
2)
00:00:17: %SNMP-5-COLDSTART: SNMP agent on host 64E32 is undergoing a cold start
I'll do a format and see what will happen.Actually I am not sure if i need to format a Flash SIMM,its not a PCMCIA card.
64E32>en
64E32#erase /?
/all  /no-squeeze-reserve-space
64E32#format /?
% Unrecognized command
64E32#erase /all ?
  nvram:  Filesystem to be erased (how can I format flash?)
64E32#dir
Directory of flash:/
No files in directory
16777212 bytes total (1657008 bytes free)
64E32#dir flash:
64E32#copy xmodem flash:
Source filename []? c3620-ik9o3s7-mz.123-22.bin
Destination filename [c3620-ik9o3s7-mz.123-22.bin]?
%Error copying flash:c3620-ik9o3s7-mz.123-22.bin (destination path is identical)  (I Google this and find nothing about it)
64E32#
